Hey Josh, are you running a stock torque converter. That could explain the hard down shifts. Or, do you have the Torque Management option tuned off? With my tune from Marty. My Torque management is turned off. Some times, it will get a harder than normal down shift when slowing down. I bet that is a much harder down shift in a stage III.
"The Sharadon stage III trans was set-up to run a 2800 to 3500 rpm stall TC. Denny said the trans works best with 3000 rpm stall TC on a 2WD." Note: The Sharadon stage III trans is set-up more for the track than the street.
The shudder, hesitate, and bump bump bump?
I would call and talk to Denny about those problems. He won't be in town until 9/14. I have to call him back on that date to find out what my options are for a 03 trans build.
Bill, are you having this same hard down shift at 30 mph? I'm guessing your Torque Management is turned off also?
