Hello, I’ve been trying to gather information on successfully swapping a 46RE into my 2006 ram 1500 4x4. My truck was tuned by Jay Greene. I do not have a diablo e or any tuner aside from HPTUNER. 545rfe lasted about a week on casual driving. I’ve since talked to Martin saine. He’s in the process of building the 46re. He mentions that he doesn’t have much experience on 46re swap on 4x4. He’s build them for people but not so much in house. Since the 06’ PCM differs than the 03 as I’ve read what exactly can be done about wiring the neutral safety switch , reverse lamps? What’s a recommended source for switch’s for OD and TC lock up?. I orders a b&m ratchet. Since I have a tune with my current motor(procharger) can I still run engine and trans with it? I do live in nj so I would need to pass. Would i need a PCM with manual transmission and have it reflashed? Forgive my ignorance but is there a TCM involved? What do I do with harness from 545rfe? I found a 46re trans adapter plate but cannot find a mount(doesn’t look like the one posted on 46re swap thread.
I had the big 3500 trans cooler and steel line from 545rfe. Can I just get away from installing 6an hose into 545rfe steel lines? Sorry if this is redundant, with 3 kids full time job I just need to get my truck back on road and it’s hard to get any information especially if something new has come
Out. Thank you.
Out. Thank you.
