Does anyone have a good wiring diagram Auto transmission for the transfer case mode sensor to the TCCM ? I would like to know were to check connections that may plug in and join it all together as I know about were it comes in to dash but want to make sure I am not missing something , I believe I have a break in the wiring but working alone its hard to use multi meter to ohm the mode sensor plug to were it plugs in the TCCM as one is under the truck an other in dash ,,I am sure there has to be at least one or more connecting plugs to get it into the cab were the TCCM is mounted,,looking for any plugs between the 2 areas if there are any,,I have traced a few feet of wiring underneath at mode sensor plug but nothing looks broken were I would have thought it would have caused issue ,,I have a transfer case mode sensor error , turn key on and 4wd selector switch lights up even neutral switch after that they all go out , if you look close they show real dim but nothing lights up when trying to select position and it has a new shift motor and cant get it to work
