If you're using the stock PCM to run the engine there is no provision in the code for an active intake. If you were swapping in a newer PCM that would be a different story. You can still use the 6.4 truck intake but you'll need an rpm switch. The last option isn't really a workable solution trying to mish mash select next gen CAN and first gen CAN together. Get an SG controller, or possibly better, Hotwireuato is now offering the SG controllers as integrated wiring swaps, i.e. they make it plug and play with your 07 PCM with a ZF trans.
