1 - 5 of 5 Posts
So I have a 2005 Ram 1500 that I put the 5.7 hemi in I have both wire harnesses and pcm but the truck won’t start or do anything someone said I could use the 2005 2500 pcm and that it would work but I’ve already switched the wire harnesses out and everything to the 2008 but that pcm is a auto trans anyone have any advice? Dodge said they didn’t think they could do anything to it to help me out which is just crazy
Welcome to our Hemi Truck Family! (y)
James
It sounds like SKIM issue. I believe that’s what it’s called. If I’m not mistake Dodge started in their 05 Rams placing a security key. I remember back when I was doing my swap, a guy put a 05 Hemi into a Dakota, and had to take the steering wheel column assembly out of the Dodge Ram too. Then he had his dealership friend come over and reprogram the Skim. When I did my swap, I order a remanufactured PCM from an 05 Ram, but told them to remove all of the security features from the program.
The only other thing I can think of would be a Park/Neutral switch issue. With the truck not knowing if it’s in either of them, it probably wouldn’t start either. Other members should be on in the near future who are a lot more savvy then I am.
You did come to the right place though. As there’s a lot of knowledge on custom builds here. Have a great day, and welcome to the family.
1 - 5 of 5 Posts
