Finally got to looking at the PCV and was wondering how I might modify it for use with a catch can. I don't like the idea that I have a vent going straight into the intake manifold. So here are a few thoughts. The PCV has two O rings, the top one seals the intake manifold vacuum from atmosphere and the lower one seals the crank case from manifold vacuum. Leaving the piddle valve as the vent for the crank case. The Crank case itself is sealed with a fresh air vent located on the Oil fill tube that many of us have disconnected from the TB inlet hose and stuck a small filter on. My thought is to block the PCV Valve and this will make the "Oil Filler Tube" Vent an actual vent for the crank case. That can be left "as is" or a Catch Can installed on the line and maybe even reconnecting the off side to the TB inlet tube.
Anyway it's raining and I'm trying to stay busy.....
