Need some help. No power at 4 pin connection, or 7 pin connection mounted in bumper. Checked all fuses and all bulbs on trailer. Truck lights work fine. Is there a hidded fuse, or relay some where that would cause this? Thanks in advance.
Hello, "BigMeanHEMI" I have an 04 1500 2wd 5.7, my tow lights haven't worked for several years now, I tried changing the whole fuse box with an 05, my tow lights started working but other things stopped working, like elect. Lock, radio, and a couple other things.had the same problem. put in a whole different circuit...for the electrical. or get it flashed.. which is a little pricey. but mine started working as soon as the circuit board was switched. Its the years of trucks. 03 and 04 have major wiring/electrical problems
this seems to be a pretty common problem amongst people I know with the same year as mine.
Okay, now in all fairness, as I did check all the fuses in both boxes, I did not test all the relays in the 05 box. I guess maybe I could do that just to cover all the bases. But the other 02 & 04 boxes wouldn't even plug into my small harnesses. So I returned both of them.This is deff weird. Is it possible that a fuse is not in one of the other boxes causing the issue after that swap? Without seeing this first hand may be difficult to actually know what's going on.
