Putting up some pics of mods done on the STS turbo kit to get this subject started.
X's 2I like this pic.
Thanks Guys. This has been such a long turbo system build.......:blink: Really happy to be at this point.:beerchug::SWEET1:
If this turbo set-up works out well. You guys now have a blue print to build your own.:brows: :thumb::thumb::thumb:
Sorry Keith. Couldn't help my self.....:lol:old dragster setup exhaust scavenger and keeps the intake spotless
That's a very good question Darell. Not sure. To be honest, haven't thought of that yet. Humm......What are you doing for PCV / engine breather setup?
Unfortunately, this is what I changed from after trying it for the last few years. I found the check valves fail after a few hundred miles at best and actually pressurize the crank instead. I had dual scavengers and any little oil vapor going through them destroys the diaphragm, even with better quality ones like OEM Ford or GM air pump check valves. Moroso ones were crap. I haven't tested my current setup yet, but there are no valves to fail now.Do what I did old dragster setup exhaust scavenger setup pulls around 2-6 in vacuum the entire run before I use to blow by dipstick out and build near 3-8psi and its very simple and keeps the intake spotless no pcv needed just send it out the exhaust
Sound interesting.there are no valves to fail now.
Wow, that is a great idea Darell. :thumb::thumb: It would have to be a little bigger than your normal sized oil separators. Humm.....dual oil separators
