Putting up some pics of mods done on the STS turbo kit to get this subject started.
Stu, I'm not sure what wire you are using, however I assume probably standard. See if you can buy a small spool of 309L .045 flux core. It would really help your welds not to break. Standard flux core has carbon which will rust fairly quickly on the thin header tubing. 309L would be the ticket. Although it might be dual shield. Call me if you have any questions. I can call my friends at Airgas and help you out tremendously on the price if need be.It's a "poor mans" turbo manifold.Put together with some thin s/s header tubing and mild steel exhaust pipe. Basically, just a cheap testing turbo manifold......:ermm:
With this present manifold, that's all I'm looking for too. My welder is an old Miller Cricket 115v Flux Core Wire Welder. Max size is .035 f/c wire. For now, it will do.Not looking for pretty just function
