41 - 58 of 58 Posts
WTF! is that mess?
Spam alert. Spam alert.
Folks - when you see spam or a problem please hit the report post icon (little red triangle next to the post). That sends a message to every moderator that there's a problem and is the fastest way to get the garbage hauled out. Unless you needed a new loius vitton knockoff handbag.....? ;)
What's the stock cam spec for the 09+ hemi's?
Copied from Chrysler's Service manual
SPECIFICATIONS
Eagle Engine - 90° V-8 OHV
DESCRIPTION SPECIFICATION
Metric Standard
Displacement 5.7 Liters 348 CID
Bore 99.5 mm 3.92 in.
Stroke 90.9 mm 3.58 in.
Compression Ratio 10.5:1
Max. Variation Between Cylinders 25%
Firing Order 1-8-4-3-6-5-7-2
Lubrication Pressure Feed - Full Flow Filtration
Cooling System Liquid Cooled
Cylinder Block Cast Iron
Cylinder Head Aluminum
Crankshaft Nodular Iron
Camshaft Cast Iron
Pistons Aluminum Alloy
Connecting Rods Powdered Metal
CYLINDER BLOCK
Metric Standard
Cylinder Bore Diameter 99.50 mm 3.92 in.
Out of Round (MAX) 0.0076 mm 0.0003 in.
Taper (MAX) 0.0127 mm 0.0005 in.
Lifter Bore Diameter 21.45 - 21.425 mm 0.8444 - 0.8435 in.
PISTONS
Metric Standard
Clearance
Measured at 38.0 mm ( 1.5 in.) Below Deck 0.031 - 0.058 mm 0.012 - 0.023 in.
Ring Groove Diameter
Top Groove 90.4 - 90.6 mm 3.56 - 3.57 in.
Second Groove 88.4 - 88.7 mm 3.48 - 3.49 in.
Weight 413 grams 14.56 oz
Piston Length 53.3 mm 2.10 in.
Ring Groove Width
No. 1 1.23 - 1.26 mm 0.048 - 0.0496 in
No. 2 1.23 - 1.25 mm 0.048 - 0.0492 in.
No. 3 2.03 - 2.05 mm 0.079 - 0.080 in.
PISTON PINS
Metric Standard
Clearance In Piston 0.005 - 0.014 mm 0.0001 - 0.0005 in.
Diameter 24.004 - 24.007 mm 0.945 - 0.9451 in.
Length 62.99 - 63.21 mm 2.47 - 2.48 in.
PISTON RINGS
Metric Standard
Ring Gap
Top Compression Ring 0.40 - 0.55 mm 0.015 - 0.021 in.
Second Compression Ring 0.24 - 0.51 mm 0.009 - 0.020 in.
Oil Control Rails 0.15 - 0.66 mm 0.0059 - 0.0259 in.
Side Clearance
Top Compression Ring 0.04 - 0.09 mm 0.001 - 0.0035 in.
Second Compression Ring 0.04 - .08 mm 0.001 - 0.0031 in.
Oil Control Rails 0.06 - 0.21 mm 0.002 - 0.008 in.
Ring Width
Top Compression Ring 1.17 - 1.19 mm 0.0460 - 0.0468 in.
Second Compression Ring 1.17 - 1.19 mm 0.0460 - 0.0468 in.
Oil Control Rails 0.387 - 0.413 mm 0.015 - 0.016 in.
CONNECTING RODS
Metric Standard
Piston Pin Bore Diameter 24.014 - 24.024 mm 0.9454 - 0.9458 in.
Side Clearance 0.10 - 0.35 mm 0.003 - 0.0137 in.
CRANKSHAFT
Metric Standard
Main Bearing Journal Diameter 64.988 - 65.012 mm 2.5585 - 2.5595 in.
Bearing Clearance 0.023 - 0.051 mm 0.0009 - 0.002 in.
Out of Round (MAX) 0.005 mm 0.0002 in.
Taper (MAX) 0.003 mm 0.0001 in.
End Play 0.052 - 0.282 mm 0.002 - 0.011 in.
End Play (MAX) 0.282 mm 0.011 in.
Connecting Rod Journal Diameter 53.992 - 54.008 mm 2.126 in.
Bearing Clearance 0.020 - 0.060 mm 0.0007 - 0.0023 in.
CAMSHAFT
Metric Standard
No. 1 58.2 mm 2.29 in.
No. 2 57.8 mm 2.28 in.
No. 3 57.4 mm 2.26 in.
No. 4 57.0 mm 2.24 in.
No. 5 43.633 mm 1.72 in.
Bearing To Journal Clearance Standard
No. 1 0.040 - 0.080 mm .0015 - .003 in.
No. 2 0.050 -0.090 mm 0.0019 - .0035 in.
No. 3 0.040 - 0.080 mm .0015 - .003 in.
No. 4 0.050 - 0.090 mm 0.0019 - .0035 in.
No. 5 0.040 - 0.080 mm .0015 - .003 in.
Camshaft End Play .080 - 0.290mm 0.0031 - 0.0114 in.
VALVE TIMING
Intake
Opens (BTDC) 28.2°
Closes (ATDC) 239.8°
Duration 268°
Exhaust
Opens (BTDC) 274.2°
Closes (ATDC) 15.8°
Duration 290°
Valve Overlap 44°
CYLINDER HEAD
Metric Standard
Valve Seat Angle 44.5° - 45.0°
Valve Seat Runout (MAX) 0.05 mm 0.0019 in.
Valve Seat Width (finish)
Intake 1.18 - 1.62 mm .0638 in.
Exhaust 1.48 - 1.92 mm 0.0583 - 0.0756 in.
Guide Bore Diameter (Std.) 7.975 - 8.00 mm 0.3134 - 0.315 in.
HYDRAULIC TAPPETS
Metric Standard
Body Diameter 21.387 - 21.405 mm 0.8420 - 0.8427 in.
Clearance (to bore) 0.020 - 0.063 mm 0.0008 - 0.0025 in.
Dry Lash 3.0 mm (at the valve) 0.1181 in. (at the valve)
VALVES
Metric Standard
Face Angle 45.0° - 45.5°
Head Diameter
Intake 50.67 - 50.93 mm 1.99 - 2.01 in.
Exhaust 39.27 - 39.53 mm 1.55 - 1.56 in.
Length (overall)
Intake 123.38 - 123.76 mm 4.857 - 4.872 in.
Exhaust 120.475 - 120.855 mm 4.743 - 4.758 in.
Stem Diameter
Intake 7.935 - 7.953 mm 0.312 - 0.313 in.
Exhaust 7.932 - 7.950 mm 0.312 - 0.313 in.
Stem - to - Guide Clearance
Intake 0.022 - 0.065 mm 0.0008 - 0.0025 in.
Exhaust 0.025 - 0.065 mm 0.0009 - 0.0025 in.
Valve Lift ( @ zero lash)
Intake 12.0 mm 0.472 in.
Exhaust 11.70 mm 0.460 in.
VALVE SPRING
Metric Standard
Spring Force (valve closed) 435.0 N +/- 22.0 N @ 45 mm 97.8 lbs +/- 5.0 lbs. @ 1.771 in.
Spring Force (valve open) 1077.0 N +/- 48.0 N @ 32.6 mm. 242.0 lbs. +/- 11 lbs. @ 1.283 in.
Free Length (approx). 55.6 mm 2.189 in.
Number of Coils 7.95
Wire Diameter 4.95 Ă— 4.1 mm 0.194 - 0.161 in.
Installed Height (spring seat to bottom of retainer) 46.0 mm 1.81 in.
OIL PUMP
Metric Standard
Clearance Over Rotors (MAX) 0.095 mm 0.0038 in.
Outer Rotor to Pump Body Clearance (MAX) .235 mm 0.009 in.
Tip Clearance Between Rotors (MAX) 0.150 mm 0.006 in.
OIL PRESSURE
Metric Standard
At Curb Idle Speed (MIN)* 25 kPa 4 psi
@ 3000 rpm 170 - 758 kPa 25 - 110 psi
* CAUTION: If pressure is zero at curb idle, DO NOT run engine.
I have a 2012 Ram Express that came with the 390 hp 5.7L Hemi. Added/changed are: Mopar cold air intake and electric fan, a BBK 85 mm throttle body, a "moderate" cam from CompCams, Shorty headers, Flowmasters with 3" tubes and a MOPAR 3.92 positraction. It ran very poorly...no tuner company had a tuner that would work on this vehicle.
Recently the tuner companies announced that they "broke the code" for the 2012 Hemi!!! I purchased a Diablo Trinity from a dealear who does performance tuning as well and has a dyno. He was able to get the truck to put down 372 rwhp @ 5450 rpms and 396.8 ft/lb of torque at 4000 rpms. However, the best he could do with 0-60 mph was 8.1 seconds. They gave up and gave me all my money back. I checked with Bully Dog. They can't do this vehicle either. I've asked CompCams what they might be able to do or if they know a solution. I've not yet heard back. They did indicate to me some time ago that the truck computer is different from the car...this may be the problem.
Does anyone know how to get this 465 FWHP Hemi to run?!?!?!?!
From what I have read and heard on other forums its going to take a few years before they get the tunes for the newer hemis down to a t. I did see a video of a 2012 jeep srt8 that was supercharged with 500 odd sum rwhp..... I'll try to find the info of the place that did that maybe they can help you.
Your welcome any time.
Thanks Mark and Janet for deleting the riff-raff.......
Big difference in the meaning of comparable and compatible in your situation
Your comp cam is of no use to you if it can't be tuned on your truck. Whether a 6.4 cam is comparable doesn't matter. What matters is the fact that it will work for you and it is better than the 5.7 cam you took out.
I had to wait a long time before they had the mods I wanted for my '10. Hopefully you won't have to wait as long as I did for compatible tuning for yours.
You could always put a 2010 computer in yours from B&G. Others have done that mod to achieve the mods they want.
Just tryin to help...:)
Janet pls remove my WTF post so as not to confuse anyone to what it is referencing. Didn't know about the "alert: button. thx
Should have my new bag in a day or two. Also pls remove this post.
Discussion starter · #58 ·
Forum is hard to use
I try very hard to reply to everyone who messages me about my postings. However, I've not been able to figure out how to do it and get the results I want. I have had personal computers since the early '80's. I get more and more tired each day of trying to figure out what some software crazy had in mind. These days I use it ONLY if it's user friendly. `sorry to those to whom I've not been able to properly reply.
D Butt
41 - 58 of 58 Posts
