09-01-2016, 11:44 AM
#6
Originally Posted by Redtruck-VA
What codes is it throwing?
I don't have any codes, took it into a dealership for a diagnostic and they gave me a print out with what was wrong, but no codes. What was said is as follows:
194136 1.00 check for active Mil lamp. codes for #3 misfire, multiple misfire, 1/1 02 sensor high/low, brake and apps sensor do not agree, #5 injector. clear codes and retry,. runs very poorly-misfire monitor shows all 4 cylinders on left bank missing badly. manifold is leaking and smells of fuel. Would need compression test and possible removal of rocker cover to inspect for worn camshaft.
They then told me is was most likely a worn camshaft and would need to be replaced at mega dollars. I am not convinced and looking for possible options.
