water/meth and nitrous - Hemi Truck Club
Old 09-09-2014, 11:10 AM   #1
pitbull greg's Avatar
i was just reading about this combination, what would be the pro's and con's of running the 2 together? what issues would i be running in to cuz i am going to do 2 stages of nitrous.
03 dodge ram 1500 quad cab
mods:
bottom end bored .30 over with hypereutectic pistons, k&n cold air intake, 2 1/2 true dual exhaust, Flowmaster muffler with side exit tail pipes , 2800 rpm edge converter, inertia big valve heads, inertia nitro spartan cam, diablo predator, 180 thermostat, new hemi coil pack conversion, detroit locker, yukon 4.56 gears, yukon axles, rear end installed by charged392, pacesetter LT headers, 6.1L fuel injector, leer tonneau cover with wing, McGaughys 4/6 drop, belltech shocks, 4 kicker L7 12's in a custom blow thru..... thats it for now
pitbull greg is offline   Reply With Quote
Old 09-09-2014, 01:23 PM   #2
Ok on a single stage kit running the methanol with a small shot pretty much allows you to leave the timing alone and use the spray. Down side to that is of the meth doesn't work the timing will be to much and bad stuff happens.
With a dual stage kit running meth will pretty much be for surpressing anything that would happen on the kits. IMO water meth is for
Boosted engs. If you run spray I would suggest just pulling the correct amount of timing for the hit you run. Using methanol and nitrous is for the people that want to push the envelope which can end badly.
Old 09-09-2014, 07:48 PM   #3
That's what I thought, every time I look it up it comes up for boosted engines. but I've been seeing more and more people talking about using them together so I was curious.
mods:
Old 09-09-2014, 08:12 PM   #4
Old 09-09-2014, 08:22 PM   #5
You can use them together I would just do it with one kit not two
Old 09-09-2014, 08:32 PM   #6
FASTHEMIRAM05's Avatar
Running water meth won't hurt ever...
Its a detonation deterrent
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
2011 Drag Truck....
Old 09-13-2014, 07:31 AM   #7
Mr. Freeze
VA4MEDS's Avatar
I've been running the Snow Stage 2 kit with a single shot for over 2 years now without any issues. They both come full on at 2700/2800. Sometimes I have to lean out the W/M if it bogs badly.
Also, 4 degrees ADVANCED timing with CO2 to chill the air intake and the 112 race fuel.
But I still keep my fingers crossed and
Old 09-13-2014, 08:01 AM   #8
I ran a snow single stage wtr/meth on my NA 03 on the street/strip. Had it set up using a vacuum switch instead of a pressure switch. I was experimenting with timing and had knock I was trying to be rid of. I have since reduced timing and disconnected it. May hook it back up at some point for the hell of it. Note: on a NA engine using vacuum you need to use a window switch to arm it and the vacuum switch to trigger it otherwise it'll run with just the ignition turned on.
