Fuel Injector Cleaner Kit - Hemi Truck Club
Old 04-01-2017, 10:39 AM   #1
Hey, check this out.
Universal Car Vehicle Fuel Injector Flush Cleaner Adapter Portable Cleaning Tool
Old 04-01-2017, 11:03 AM   #2
Interesting. Just don't strike a spark .
Old 04-01-2017, 11:06 AM   #3
CavRam's Avatar
2014 Ram 1500 Express
Old 04-01-2017, 11:09 AM   #4
Talking
Old 04-01-2017, 12:02 PM   #5
Old 04-02-2017, 05:26 AM   #6
Yeah all well and good as long as that's not flammable stuff lol and it should be a pulsed hook up not straight battery that's a sure way to dry an injector winding
Old 04-02-2017, 05:57 AM   #7
Isn't 12v too much for the injectors? They operate at a lower voltage don't they?
Used a 9v battery to flush the stage 1 caliber injectors from a spare wiring harness. Had the fuel rails hooked up to the trucks fuel system. Definitely made a difference with cleaner out injectors even though it was with just bleed off pressure. Have a power supply bypass for the fuel pump now. So now I can really flush out the fuel injectors with 58psif.
Old 04-02-2017, 06:34 AM   #8
No they actually get running voltage around 13.4-14.5v bit they are on for milliseconds so they don't build heat. They are controlled by ground in the pcm. I have an injector tester at work I use to check pressure drop and it sounds like a machine gun clicking it's relay to pulse the injector to spray
Old 04-03-2017, 04:02 AM   #9
I actually have a kit something lke that. Mine you hook up to the fuel rail and pull the fuel pump fuse. The start the engine and let it run off the can of cleaner
_________________________
Old 04-03-2017, 04:52 AM   #10
Where did you get that kit from?
