D150 Project - Hemi Truck Club
Old 06-04-2016, 08:39 PM   #1
FASTHEMIRAM05's Avatar
D150 Project
Soo... hopefully I will finish this project.
Since a little girl is on the way it made more sense to get a family/work truck so I put the 2012 back to stock and traded her in on a 2016 Nissan Frontier.
That being said I now have a shelf full of awesome parts for Hemi's and Rams. I've decided to turn the D150 into a Street/Strip Beast.
I'm Gonna drop the Built 5.7 Hemi in her along with the Built 545 I have. Also scored a Dana 60 today which will help put that power to the ground. I hope to do a full triangular 4 link with coilovers for the rear suspension but have not completely figured that out yet.
This past weekend i started tearing it apart. Pulled rear bumper and disconnected everything to be able to remove the bed so I can start the rear suspension and axle parts.
Keith... I need ya buddy!!
Old 06-05-2016, 04:20 AM   #2
Oh what fun this will be!
Old 06-05-2016, 06:01 AM   #3
Old 06-05-2016, 06:12 AM   #4
I recommend before settling on using the 545RFE read up on what sensors the trans will require to operate. There are no stand alone systems for it so the trans will need to be incorporated with the pcm. I would suggest a 727 for strip use or a A518 street. Both of these are stand alone transmissions. 1st gen's are very cool in my book. I have a 89.
Old 06-05-2016, 06:48 AM   #5
Carrolls Ram's Avatar
Doesn't PCS make a full stand alone for the 545?
__________________________
2015 Ram 2500 CTD CCSB 4x4
07 Turbo Ram: Sold
Carrolls Ram is offline   Reply With Quote
Old 06-05-2016, 07:02 AM   #6
He has a computer and a harness guys. We can make it work I'm sure. And the dash in the truck is old school so simple guages/sensors will work.
Old 06-05-2016, 07:06 AM   #7
I know Megasquirt was trying to, but I don't believe anyone has succeeded, ther's no driving force with the 545 known weaknesses.
Old 06-05-2016, 07:28 AM   #8
All things can be done with enough effort and resources. But just pointing out the 545 needs sensor inputs, one being a VSS and neither the original nor the Dana rear axles have the sensor. Now, a 46RH tail housing does have a sensor that I think can be substituted for the rear axle sensor. Just takes a lot of research to select the parts that are compatible. OBTW, I really like that dana.... nice find.
Old 06-05-2016, 09:37 AM   #9
Here combinations that you might consider.
1. If you want to use the 545 trans, look at the 4.7 pcm. It has a cable driven TB and would still support the 545 trans.(except the VSS is still a issue)
2. If a stand along trans is used, then the Megasquit engine manager is what I'd look at. This would allow tunability for any power adders you could ever want to use, a cable driven pcm, and the dana would be no issue.
Old 06-05-2016, 10:08 AM   #10
I'm gonna contact AdvanceAdaptors.com on Mon to see if there's any way to retrofit the toner wheel from a 9.25 to a dana 60 or any other way of going about adapting a vss to the output of the 545
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
2011 Drag Truck....
