05 Mods & Maintenance - Page 151 - Hemi Truck Club
Like Tree619Likes
Old 07-21-2020, 07:27 AM   #1501
Mark G Senior Member
bada44's Avatar
You cannot stress the importance of the IAT sensor anymore that. It will save your engine from detonation!
Redtruck-VA likes this.
Please Donate today!
I STAND FOR THE FLAG!
[email protected]
Old 07-21-2020, 03:03 PM   #1502
Have no intention to put it there on the 05. That's why I'm looking for a screw in type iat sensor.
With the 03, I've tried it in a few spots including right before the tb. It ran better and had better afr readings all around with it at the turbo inlet. But, that was the 03... Not with the 05.
Old 08-10-2020, 02:21 PM   #1503
After wrapping the hot side turbo piping and down pipe. It quieted down the exhaust sound down around the engine. Then I heard another exhaust leak coming from the front of the engine. The leak was coming from the flex bellows on the up pipe to the turbo. It had separated at the weld sleeve. Didn't even know there was an exhaust leak there until wrapped the turbo pipping. That's why the turbo boost up seemed to be a little slow. There was now way to weld it up. Had ordered and received the new turbo flex joints.
The new turbo flex joint.
Old 08-10-2020, 02:33 PM   #1504
Installed the new turbo flex joint on the up pipe to the turbo. Took the 05 for a test drive. The turbo boost up is much better now. Not as sluggish either at low rpm. Still have to replace the Y pipe flex bellows. Moving forward at least.
arocketman, bada44 and RAM4 like this.
Old 08-14-2020, 03:14 AM   #1505
Had a real bad day at work....
Felt much better after taking the 05 for a little drive.
arocketman, charged392 and bada44 like this.
Old 08-16-2020, 04:18 PM   #1506
Have the driver side header and the Y pipe off the truck. Bracing up the header & Y pipe as well as installing the turbo flex joint.
Old 09-14-2020, 09:36 AM   #1507
Finally finished the Y pipe flex joint change out with bracing/brackets. It took me a while due to I got sick. Feeling much better now. It was some kind of bug I guess... The truck is running good and is boosting up much better. Didn't realize that both flex bellows where leaking by. Added bracing to both header and Y pipe as well. With the coil pack install and fixing the exhaust leaks has made the engine run better inline with Keith's tune. She really runs good now with Keith's tune. You da man Keith.
arocketman and bada44 like this.
Old 09-20-2020, 07:42 AM   #1508
Going to get my wiring straightened out. It needs a little tlc...
https://www.jegs.com/i/Painless-Perf...70118/10002/-1
https://www.jegs.com/i/Painless-Perf...30100/10002/-1
Old 09-21-2020, 03:27 PM   #1509
Will this spot be ok for the IAT sensor?
There was already a plug fitting there on the OCP intake manifold and I didn't have to extend the IAT plug wiring.
Old 09-22-2020, 06:14 AM   #1510
My concern with plugging into the cast manifold is heat soaking the sensor.
SUPER BEE likes this.
« Mods in motion | - »
