05 Mods & Maintenance - Page 108 - Hemi Truck Club
Like Tree376Likes
Old 08-13-2019, 09:46 AM   #1071
Originally Posted by bada44 View Post
Nominal Flow Rate 1015cc/min @ 3.0 Bar (43.5 psi)
Good Lord! Those just seem to be a little over kill in consideration that your not even going to run the truck down the track. My 03 with the 348 and a turbo only had 55lbs (570cc/min) injectors running 12-14psi boost. The same injectors since 2009 when it had a rear mount turbo. Guess it's all about the tune.
Old 08-13-2019, 06:53 PM   #1072
I set mine to 58PSI no port used at all. My injectors are 96lbhr and a 525lph pump. Set and forget has worked from 2007 for me and over 100,000 on same motor with some minor repairs here and there. If you over complicate a simple task to much can go wrong to fast!!
Old 08-14-2019, 02:48 AM   #1073
Yes, would like to have it that simple. When I get the time to get the 05 ready for tuning again... Will go by what the new tuner wants me to set the truck up as for his tuning.
Old 08-14-2019, 02:53 AM   #1074
Originally Posted by Ghost03hemi View Post
Rick, would it be worth it to try porting out the plenum and the outer runners to help the air flow at lower rpms?
This is a side pic looking into the center two ports. It just seems like the outer ports can be ported for better air flow into them?
Rick, what if only the outer runners where polished as well?
Old 08-15-2019, 12:28 PM   #1075
ric3xrt's Avatar
I'd try it at this point you have nothing to lose.
[email protected] , Not bad for a 392Ci NA 4400 lbs truck ,
Old 08-15-2019, 05:18 PM   #1076
Humm..
arocketman and ric3xrt like this.
Old 08-16-2019, 02:00 PM   #1077
ric3xrt's Avatar
Humm..
That's purty looking.
Old 08-16-2019, 02:39 PM   #1078
Just researching some pic's to open up the plenum some.
Old 08-24-2019, 03:12 PM   #1079
Thinking very seriously of trying out this fabricated intake manifold. Might have to mod it. Will definitely have to mod the front timing cover... It's not a bad price either. $569.95 It's much cheaper than the OCP EFI duel plane intake manifold. Includes the fuel rail kit and O-ring gaskets.
Holley Sniper EFI 837262 Sniper EFI Race Series Fabricated Intake Manifold - Gen III Hemi
Old 08-24-2019, 04:05 PM   #1080
But, after reading this. Not so sure now. Thanks Rick for the info.
https://ls1tech.com/forums/forced-in...-review-3.html
