Did rear bearings today- DYI - Hemi Truck Club
Go Back   Hemi Truck Club > State Chapters of HTC.com > California Chapter
Like Tree4Likes
Old 07-03-2012, 07:44 PM   #1
chefred112's Avatar
hey all, work made me take today off because i worked saturday , so i decided to get autozone loaner tools and do my rear bearings today... at first I was going to use autozone bearings but they didn't fit right so i got dealer bearings (1-03507898AB)..if you got time before you do yours, get it online from one of the mopar sites..waay cheaper ($35 vs $58).. anyways..here is how i did them..
1) put truck on jackstands and remove wheels
2) unbolt rear calipers (21mm) and rest them on the leafs, remove rotors
3) remove 12 bolts (13mm) from diff cover an drain rear end
4) unbolt pin bolt (8mm) and remove pin from carrier
5) push in axles, remove C clips in carrier, then pull out axles
6) using bearing puller, insert into bearing, then pull on it to secure the puller onto bearing edge, then tight the nut which secures the flat washer onto outter seal.
7) screw on slide hammer onto bearing puller, it took 4-5 whacks on it and the bearing and seal popped out (I was careful not to break the seal because i reused them)
8) clean out axle end where bearing came out of and apply grease liberally in it.
9) also apply grease liberally onto new bearings and rotate several times to work the grease into it.
10) put new bearings in and tap around the edges to get it to "bite" into axle housing, i then used the old bearing, placed it on top of new one and proceed to whack on the edges of it to press the bearing into axle housing, it will recess into axle, then i tapped the seal on an proceeded to tap on the edges until the seal was flush with edge of the axle housing.
11) wiped axles and re inserted them into housing and C clipped them in the carrier.
12) inserted pin back into carrier and bolted
13) put rotors, calipers back on and put the wheels back on.
14) put fluid in and then put the truck back onto ground...that's it..I'll post the few pics I took shortly...
__________________________
-fast freddie- 392 hemi :)
Old 07-03-2012, 07:44 PM   #2
chefred112's Avatar
Old 07-03-2012, 08:21 PM   #3
chefred112's Avatar
Redtruck-VA likes this.
Old 07-04-2012, 12:45 AM   #4
BigART's Avatar
Nice man, you may just need to open your own shop soon.
_____________________________________
11' 2500 Crew 4x4 Laramie SB w/4.10 Gears [email protected]
Mods: AMSOIL Fluids & Filters, a few go fast parts, Carli 2.0 Suspension, AMP Steps, Toyo 35" MT's
www.facebook.com/PureSynRacing
AMSOIL Dealer - www.OilPros.net 1-855-OilPros, contact me for wholesale pricing or ask for a free catalog. Use Referral #470077
Old 07-04-2012, 08:42 AM   #5
Hemi4ever's Avatar
Nice , can I be next.
Watch out for the Brentwood PD , They give no breaks.
Hemi4ever is offline   Reply With Quote
Old 07-04-2012, 01:56 PM   #6
chefred112's Avatar
it's easy dude..let's do it!
Old 07-04-2012, 01:58 PM   #7
chefred112's Avatar
man..if it would have fit, the autozone bearing was nice (timken)...it already had a seal on it as opposed to separate in oem form.
Old 07-04-2012, 02:47 PM   #8
chefred112's Avatar
I used Thor..it makes installations really easy..
Old 03-20-2019, 07:50 PM   #9
to swap a 360 with a 727 trans. What is the mopar performance part number for the spacer that goes on the shaft. Thanks in advance.
russ_810 is offline   Reply With Quote
Old 03-21-2019, 12:15 AM   #10
Might read the thread on A518 install which is in the 727 family.
https://www.hemitruckclub.com/forums...ild-17576.html
ric3xrt likes this.
