Ballistic Fabrication - Hemi Truck Club
Go Back   Hemi Truck Club > State Chapters of HTC.com > Arizona Chapter
Old 08-14-2011, 12:56 PM   #1
Copy & Paste from DTX-
BALLISTIC FABRICATION HUGE CLEARANCE STARTS IMMEDIATELY THIS is not a SALE!
In an effort to refocus the company's attention on the customer, Ballistic Fabrication has drastically reduced the number of available items for sale. Over the past 5 years, these items have proven to be slow in sales and simply take up too much time and effort.
Tucson, AZ 12 August 2011 -- After careful review of our business operation, the decision has been made to make drastic changes which will allow our company to again focus on the most important part of our company. The customer! Ballistic Fabrication has reduced its manufacturing product line drastically by cutting parts from their sku line up.
Reducing the product line allows our company to free up time in almost every area. The design team will be able to work on more needed parts for the 4x4 industry, our laser and press brake will not be tied down with as many jobs for parts that end up sitting on the shelf.
By eliminating so much of the added work, we will be able to focus more clearly on the needs and wants of our customers, and be able to process orders more quickly than ever because the parts the customer wants, will be on the shelf! Shocks are still available, but by phone order only.
"Our customers are the number one priority, while we may have lost sight of that for a short time, we are 100% recommitted to the customer and their needs." said Jeff Bullock, President of Ballistic Fabrication, LLC.
Ballistic Fabrication is making the adjustments that are necessary for business. By reducing product, the focus is centered and allows more freedom and flexibility in assisting the customer!
Contact:
David Christensen, General Manager
520.888.4441
http://www.ballisticfabrication.com/
Here is a list of what is still in stock from the discontinued items.
This is the best price you'll EVER find on this stuff, so get yours now! This deal is only good until the goods are gone!
You must call in your order 520.888.4441
Parts will ship same or next day depending on the time of day the order is placed.
Part #
BRK-1029 2.0 in. Tube Flange 2 bolt design (2 pieces) $5.00
BRK-1002-1 Panhard mount with 6" separation plates 2.5" Axle Diameter $15.00
BRK-1002-8 OFFSET Panhard / Tracbar Mount 3.5" axle, 6 inch separation $15.00
BRK-1003-1 Panhard mount with 7" separation plates 2.5" Axle Diameter $15.00
BRK-1003-5 OFFSET Panhard / Tracbar Mount 2.5" axle, 7 inch separation $15.00
BRK-1004-1 Link axle tower 7" separation 2.5" axle diameter $15.00
BRK-1004-11 Link axle tower 7" separation 2.75" axle diameter $15.00
BRK-1004-5 Link axle tower 7" separation 2.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1004-8 Link axle tower 7" separation 3.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-1 Link axle tower 8" separation 2.5" axle diameter $15.00
BRK-1005-11 Link axle tower 8" separation 2.75" axle diameter $15.00
BRK-1005-4 Link axle tower 8" separation 3.5" axle diameter $15.00
BRK-1005-6 Link axle tower 8" separation 3.0" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-7 Link axle tower 8" separation 3.25" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-8 Link axle tower 8" separation 3.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1006-1 Link axle tower 9" separation 2.5" axle diameter $15.00
BRK-1006-11 Link axle tower 9" separation 2.75" axle diameter $15.00
BRK-1006-7 Link axle tower 9" separation 3.25" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1006-8 Link axle tower 9" separation 3.0" axle diameter 3.5" Mounting width, 3/4" hole $15.00
BRK-1007-3 Lower axle link bracket 2.5" axle diameter, Ten Degree Offset, 2.63" 9/16" $15.00
BRK-1007-4 Lower axle link bracket 2.5" axle diameter, 22.5 Degree Offset, 2.63" 9/16" $15.00
BRK-1007-5 Lower axle link bracket 2.5" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1007-6 Lower axle link bracket 2.5" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1007-8 Lower axle link bracket 2.5" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-6 Lower axle link bracket 3.0" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-7 Lower axle link bracket 3.0" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-8 Lower axle link bracket 3.0" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-5 Lower axle link bracket 3.25" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-6 Lower axle link bracket 3.25" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-7 Lower axle link bracket 3.25" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-8 Lower axle link bracket 3.25" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1010-2 Lower axle link bracket 3.5" axle diameter, Five Degree Offset, 2.63" 9/16" $15.00
BRK-1010-7 Lower axle link bracket 3.5" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1010-94 Lower axle link bracket 4.0" axle diameter, 22.5 Degree Offset, 2.63" 9/16" $15.00
BRK-1010-95 Lower axle link bracket 4.0" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1017-1 Link tab (pair) 3/16" $1.00
BRK-1017-2 Link tab (pair) 1/4" $1.00
BRK-1017-3 Link tab (pair) 3/8" $1.00
BRK-1021-5 Two wrap around 1.25" link brackets (two pieces) $3.00
BRK-1021-8 Two wrap around 1.25" link brackets (two pieces) $3.00
BRK-1037-1 Coilover mount self jigging assembly (2 mounts) for 2.5" axle diameter $10.00
BRK-1046-1 Weld-on tube end (1) for 1.25" tube $1.00
BRK-1050-1 Flat bottom radius arm / coil mounts (2) 2.5" axle diameter $15.00
BRK-1057-1 Axle tube shock tabs 2.5" axle diameter 3/16" plate $1.00
BRK-1057-21 Axle tube shock tabs 2.75" axle diameter 3/16" plate $1.00
BRK-1057-5 Axle tube shock tabs 3.25" axle diameter 3/16" plate $1.00
BRK-1057-7 Axle tube shock tabs 3.5" axle diameter 3/16" plate $1.00
BRK-1058-3 Dual Flat Bottom Shock Tabs - 4" Length $5.00
BRK-1058-4 Dual Flat Bottom Shock Tabs - 5" Length $5.00
BRK-1058-5 Dual Flat Bottom Shock Tabs - 6" Length $5.00
BRK-1059-51 Axle link / coilover mount 2.5" axle 22.5 degree angle for 3.0" 3/4" joints $25.00
BRK-1063-1 Radius Arm - Coilover/shock mount 2.5" axle $25.00
BRK-1063-3 Radius Arm - Coilover/shock mount 3.25" axle $25.00
BRK-1063-4 Radius Arm - Coilover/shock mount 3.5" axle $25.00
BRK-1065-6 Universal long tab 3/8" plate 1/2" hole $1.00
BRK-1067-1/2 Flat bottom radius arm mount 2.5" Axle tube 2.5"/3.0" Mounting Width $15.00
BRK-1074-6 HD Link Tabs 1.5" Long $5.00
BRK-1076-1 Link Tabs 1.75" Short 1/4" $5.00
BRK-1076-2 Link Tabs 1.75" Medium 1/4" $5.00
BRK-1076-3 Link Tabs 1.75" Long 1/4" $5.00
BRK-1076-4 Link Tabs 1.5" Short 1/4" $5.00
BRK-1076-5 Link Tabs 1.5" Medium 1/4" $5.00
BRK-1076-6 Link Tabs 1.5" Long 1/4" $5.00
BRK-1077-6 High Clearance Shock Tab 2.0" $1.00
BRK-1079-1 HD Tie Down Tabs - 2.5" axle (pair) $3.00
BRK-1079-3 HD Tie Down Tabs - 3.25" axle (pair) $3.00
BRK-1079-4 HD Tie Down Tabs - 3.5" axle (pair) $3.00
BRK-1080-3 Axle tube LINK Tabs 2.75" (pair) $1.00
BRK-ROC-1108-4 Rockwell Link bracket w/ Coil mount 3.0" mounting width 3/4" hole NEW 15 degree ANGLE $30.00
BRK-ROC-1111-2 Rockwell Link bracket w/ COILOVER mount 3.0" mounting width 3/4" hole NEW $30.00
DIF-2004-2 Eaton Differential Cover - 3/8" Steel - WELDED and MACHINED $80.00
DIF-2005-2 Dana 35 Differential Cover - 3/8" Steel - WELDED and MACHINED FLAT $69.99
DIF-2009-2 Xterra C200 Differential Cover - 3/8" Steel, M10 Bolts - WELDED and MACHINED FLAT $75.00
DIF-2010-3 AAM 9.5 Differential Cover WELDED $80.00
HMS-519 High Misalignment Spacer for 7/8" bore to 1/2" (303 SS) $5.00
HMS-520 High Misalignment Spacer for 1.25" UNIBALL to 3/4" (303 SS) $5.00
MISC-621-1 Billet Steel Tube Caps 1.0"-1.25" $1.00
MISC-621-4 Billet Steel Tube Caps 1.75"-2.0" $1.00
MISC-621-8 Billet Steel Tube Spikes 1.75"-2.0" $5.00
SAF-682 303 Stainless Steel 1/2" Safety Washer $2.00
SAF-683 303 Stainless Steel 7/8" Safety Washer $2.00
SPA-550-1 Universal Spacer 9/16" bolt hole 5/16" width $2.00
SPA-550-5 Universal Spacer 3/4" bolt hole 5/16" width $2.00
SPA-550-6 Universal Spacer 3/4" bolt hole 7/16" width $2.00
SPA-561 Step Down spacer 5/8" to 1/2" with 1/16" shoulder $2.00
SPA-563 Step Down Spacer 5/8" to 1/2" with 1/4" shoulder $2.00
SPA-566 Step Down Spacer 7/8" to 5/8" with 1/16" shoulder $3.00
SPA-567 Step Down Spacer 1.0" to 5/8" with 1/2" shoulder $5.00
SPA-568 Step Down Spacer 1.0" to 9/16" with 3/8" shoulder $5.00
SPA-580 Reducing Spacer - 9/16" to 3/8" (CRS) $1.00
SPA-591 Reducing Spacer - 7/8" to 3/4" (CRS) $1.00
SPA-592 Reducing Spacer - 1.0" to 9/16" (CRS) $1.00
SPA-595 Reducing Spacer - 1.0" to 7/8" (CRS) $1.00
LIMITED QUANTITIES! Call now for the best deal EVER!!!
Old 08-15-2011, 02:19 PM   #2
LoveLauren
uhmmm...their customer service and ability to get parts made still sucks. ive been going there the past 3 weeks to get clamps mike needs and they still dont have them ready.
haha...theyre going to focus on the customers
