SRT 10 Oil Temp Gauge Install - Hemi Truck Club
Old 11-04-2009, 08:33 AM   #1
1quik4's Avatar
I just bought a pillar and oil temp gauge from an SRT 10 for my '05 Hemi.. Its just the gauge, what will I be needing to get this to work correctly in my truck? Thanks...
1quik4 is offline   Reply With Quote
Old 11-04-2009, 07:41 PM   #2
afteamroper's Avatar
what brand and model gauge is it? you could start here if it is an autometer gauge http://autometer.com/cat_accessorieslist.aspx?pid=8 and then you will need a wireing harness for it as well
afteamroper is offline   Reply With Quote
Old 11-05-2009, 07:38 AM   #3
That gauge is made by autometer in their OEM dept so they don't sell a harness or sender that is made specifically for it. Basically you have to call their tech support and get a sending unit for a full sweep oil temp gauge and then figure out how to connect wires to it as they don't sell the harness for the sender your going to need. Once you see the sensor you'll see why I said figure out how to connect it. It uses the really small pin style connectors that are right next to each other.
If you can figure out that part the gauge is pretty much self explanatory as it is power, lighting, ground, and one wire to the sending unit.
Henson Motors is offline   Reply With Quote
Old 10-17-2010, 05:24 PM   #4
HEMI&ampVIPER
Has anyone been able to get the srt oil gauge to work in a 03,04,05 hemi? What is needed?
Old 10-19-2010, 10:05 PM   #5
xtrmes's Avatar
You will need the two items listed below. Although you really don't need the harness. It just makes it easier on you if your not good at wiring.
Sender for 100 PSI Oil & Fuel (Full Sweep)
Product #
2246
1/8" NPT Male Thread.
Wiring harness for Full Sweep Electric Temperature Gauges
Product #
5226
xtrmes is offline   Reply With Quote
