Well, I just bought some 2012 Limited Edition, full leather, full power (driver and passenger), heated and cooled, crew cab seats to replace the stock cloth seats in my 2004 QC.
The rear seat should fit with a little modification to the mounting brackets. Something like cutting off a couple inched at the rear and drilling new mounting holes in it. I'll loose a little leg room in the back which is actually fine since I don;t usually have people back there and when i do, they are smaller and usually female.
The front seats are a direct bolt in and I know that I should be able to tap power from the drivers side harness I already have. The question is, will that also power the seat heaters and I assume that I need to install on/off switches for driver and passenger heat as well. Then there is the cooling part. Not sure how that actually works. Does it need to have the ducting in place for the actual cooling? Is there some sort of fan on the bottom of the seats to blow air up my a$$?
Even if I only get the driver side power working, I'll be happy. I can't wait to install these things!
Also, what is the best way to clean and condition leather seats like these?
I didn't get the console show in the pick, I don;t want to try and install that in my truck, I want to retain a jump seat so I am searching for a matching jump seat with cup holders now. Might have to get a standard cloth one and have it recovered to match.
