seat belt lite on the dash - Hemi Truck Club
Old 09-28-2007, 11:51 AM   #1
hemimike06's Avatar
does anyone know who to make the light go off on the dash for the seat belt i was able to get rid of the dinging but the light is driving me nuts on the car i have i was able to disconnect the wire the leads down under the seat.but on the ram i see a few wires i thought i disconnected the right plug for it but its still on maybe i have to diconnect more then one plug by the way it has power seat no heat
Old 09-28-2007, 05:10 PM   #2
TheBoss's Avatar
Easy, put it on. LoL... I don't know really. I have an '03, and it just leaves the seatbelt light on when not used.
Old 09-28-2007, 06:03 PM   #3
Fly_N\_Low_Hemi
Take the bulb out or plug the wire back in.....
Old 09-28-2007, 07:22 PM   #4
hemimike06's Avatar
fly n low! what do you mean plug the wire back in? i unplugged the wire but the lite still stays on maybe its the wrong plug i pulled off but i think there is more than one plug
Old 10-01-2007, 02:19 PM   #5
Fly_N\_Low_Hemi
Ok, I think I misunderstood your first post. I couldn't say why the light is staying on then....
Old 10-01-2007, 08:38 PM   #6
&quotRANCHER&quot
The light stays on because the circuit isn't complete. It should tell in your owners manual how to disable it. Hook the wires back and read your manual. I'm not sure how you do it on the 06's, but you can turn the light and bell off without harming your truck..
Old 10-01-2007, 09:34 PM   #7
madcat's Avatar
06' manual tells how to disable the audible, but it does not disable the dash light….
Disclaimer: *I by NO means endorse, or even infer that I recommend, have, or would ever do this.*
Now that the legal chit is out of the way, Rancher is correct, sensor/light is waiting on a normally closed (short between two wires) to turn the dash light off, unplugging the sensor will not help. You are going to need to locate the two wires, going up the seatbelt (mounted under seat) chase. Easiest to access from back seat, drivers side, closest to center consol. Once the two wires are found, do what you go to do to short them together…..NO more light.
Old 10-02-2007, 08:00 AM   #8
&quotRANCHER&quot
quote:Rancher is correct,
That'll cost ya a cold one!!! Hows the hunting Phil?
BTW...I think when you disable it, it also turns out the light. At least it did on mine! This message has been edited. Last edited by: "RANCHER", document.write(''+ myTimeZone('Tue, 02 Oct 2007 07:26:31 GMT-0700', '02 October 2007 10:26 AM')+''); 02 October 2007 10:26 AM
Old 10-02-2007, 01:03 PM   #9
Sideshow's Avatar
Quite a few years ago, I had a warning light on one of my cars that just wouldn't go away....I found that a small piece of electrical tape took care of it very nicely (tape over top of the light)!
Sideshow is offline   Reply With Quote
Old 10-11-2007, 12:19 AM   #10
madcat's Avatar
quote: Hows the hunting Phil?
HOT, and more HOT!!!
Actually seen quite a few, and some within range, but no wall hangers yet.
