pillar pod question - Hemi Truck Club
Old 03-24-2008, 07:48 PM   #1
"Bob"
motorscooter's Avatar
pillar pod question
you guys that have put these in.i'am putting in a trans temp,oil pressure, water temp. do i still have to hook up the stock gauges to make the computor happy or can i leave them disconnected and not have any ill affects
Old 03-24-2008, 10:16 PM   #2
pillar pod question
Are you using factory wiring and sensors to the transmission temp,oil pressure and water temp?
Old 03-24-2008, 10:22 PM   #3
The Original Bee
HemiSuperBee's Avatar
pillar pod question
the check gauges light will probably come on if you disconnect them.
Old 03-25-2008, 12:01 AM   #4
"Bob"
pillar pod question
thats what iam trying to find out can i put a t in so they both work and won't give me check engine. the trans temp should not efect anything scince it comes right off pan and is not part of the nazi comp.
Old 03-25-2008, 06:26 AM   #5
pillar pod question
The gauges you want to hookup tap into different places then the stock gauges. The water temp goes into the block on the passenger side between the motor mount and the trans. The oil pressure will go right below the factory sender above the oil filter. I hope you got electrical gauges, the mechanical ones are more difficult to install. If you didn't get any yet, that is what I would recommend.
Old 03-25-2008, 07:13 PM   #6
"Bob"
pillar pod question
thanks hemi jeff, i think i got it. so i don't have to mess with either of the stock ones these are different locations to hook up to.
yes there electrical.
Old 03-25-2008, 07:16 PM   #7
CentralTexHemi's Avatar
pillar pod question
Bob FYI with that many A Pillar guages and from the looks of it you have dark tinted windows say goodbye to being able to see out your driver side window at night the window acts like a mirror for the guage lights I will never do an A pillar again
Old 03-25-2008, 07:28 PM   #8
"Bob"
pillar pod question
thanks CTH.i run my lights pretty dim but i may but those colored rubbers on the bulb and see how that does.
Old 03-25-2008, 07:35 PM   #9
pillar pod question
Nope, the gauges tap into other spots not used by the stock stuff. Electrical gauges are so much easier to install. The speed shop gave me some free gauges last week when I was inquiring about them but 1 of them was a mechanical gauge and the other 2 cost $100 combined brand new so I kindly refused. If they were the Phantom gauges I woulda had them installed already though. The colored covers for the bulbs suck IMO. I had them on before and they give off a color not close to the cover. If you wanna change the light color spend a few extra $ and get the LED replacement lights.
Old 03-25-2008, 09:03 PM   #10
"Bob"
pillar pod question
thanks again hemi jeff. these are mooneye gauges and i really want to use them,old school look
