Painting over oem chrome plated plastic grill - Hemi Truck Club
Old 06-29-2010, 02:33 PM   #1
ROLLING THUNDER's Avatar
I want to paint my OEM chrome grille on my 07. Will paint bond to the chrome surface? If so, what kind of prep is required?
R/T
Old 06-29-2010, 07:27 PM   #2
&quotRANCHER&quot
If I rmember rignt it's plastic. Start with 600 grit wet sandpaper then 1000 grit and some laquer thinner and it should be ready to prime.
Old 06-30-2010, 06:18 AM   #3
Thank you Doug
Yes it is plastic
N
Old 06-30-2010, 11:20 AM   #4
madcat's Avatar
It's actually a VERY thin sheet of almost foil like material... sanding too much will sand thru that material... just scuff it a little with 1,000 grit, a really quick wipe down of laquer thinner, plastic primer, then paint.
Old 07-24-2010, 03:33 PM   #5
Farrrrrr East Coast
NewfieBullet's Avatar
duplicolour makes a great adhesion promoter for plastic too
Old 07-25-2010, 10:20 PM   #6
JustHemi's Avatar
I have some, only I think it is 3M that I have.....
Old 12-19-2010, 04:55 PM   #7
MADBRAD's Avatar
This is on my mod list as well. Im either gonna sand thru the chrome or spend $75 at Certi fit for a paintable one. Gonna color match the grill.
MADBRAD is offline   Reply With Quote
Old 01-26-2011, 02:24 AM   #8
MADBRAD's Avatar
Ended up getting the new grille shell fron Certifit. Havent painted it yet because it came molded black. Decided to run it that way til spring.
Old 01-26-2011, 06:15 PM   #9
Mopower or no Power!!
3rd Strike Performance's Avatar
As cheap as the replacement grille surround is, and the fact it is easier to paint, you would be better off getting a new one than painting the chrome one. It will eventually flake off the chrome one, regardless of whether or not you use adhesion promotor, simply because chrome does not let paint stick worth a crap.
3rd Strike Performance is offline   Reply With Quote
Old 07-16-2011, 09:22 PM   #10
uncbob's Avatar
Yeah that is what happened to me and I had the pros do it
Did last close to 5 years though but bought a replacement black for $49 and just had it painted blue just over a week ago
uncbob is offline   Reply With Quote
