led interior lights - Hemi Truck Club
Old 11-27-2011, 03:45 PM   #1
cbb05's Avatar
has anyone put led light in their map/dome light? i tried and when install them they stay lit but very dim and then when you turn them on they actually go off...when in the off pos. and open the sun visor mirror they come on...the list of crazy things go on...i tried resistors 1/4 watt 470ohms but it made them flash like strobe lights...any help would be great thanks
cbb05 is offline   Reply With Quote
Old 11-27-2011, 03:45 PM   #2
cbb05's Avatar
Old 11-27-2011, 04:01 PM   #3
HemiByrd's Avatar
There are a lot of products available from Amazon.
http://www.amazon.com/s/ref=nb...D+dome+light&x=0&y=0
Old 11-27-2011, 06:47 PM   #4
I custom made a dome light with 12 blue LEDs and a resistor completely did away with the white lights in the truck no issues at all but mine also is not a store bought bulb never tried to change the map lights out just removed them
Old 01-12-2012, 07:09 AM   #5
Bohica's Avatar
I put in LEDs that do exactly the same thing, along with some other weird behavior. They never turn completely off, unless it sits over night and they aren't turned on. For some reason I don't mind them being dim while driving at night. As for keeping both of them on, I use the interior light wheel by the headlight switch to control them instead of pressing them in. I'm not sure if it's because I used cheap LEDs or the different load on the circuit.
07 SLT Quad Cab
Plenty of 'tasteful' mods
Bohica is offline   Reply With Quote
Old 03-08-2012, 06:55 AM   #6
OldBaldie's Avatar
Standard incandescent bulbs are not polarity dependent (+/-) like LEDs. To that end, you may have them in backwards.
Our overhead map & dome lights are controlled on a dimmer circuit, and this will cause problems with the LED operation unless a properly sized resistor (100 ohm/1 watt will do nicely) is soldered across the two terminals (not for the uninitiated); use a proper soldering iron for electronic work and DO NOT use the acid core solder for your radiator.
I have replaced my overhead lights with LEDs, and I can read a book from the light they put out. I used Cool White as the color, and got them from SuperBrightLEDs.
There are a number of threads on this site from members that have done this.
With proper planning, they will give you much enjoyment.
Make sure that your walk talks, louder than your talk talks.. Jesus rules!
When you put the gun in the holster, put the ego in the gun safe!
I view Nitrous like that hot chick with an STD; you want to hit it, but you're afraid of the consequences....
OldBaldie is offline   Reply With Quote
