connecting blaupunkt navigation - Hemi Truck Club
Old 04-12-2005, 04:09 PM   #1
I'm want to connect my blaupunkt navigation.
for that i need a speed signal, I have the manual and found out the speedometer in the instrument cluster gets the vehicle speed from the pci circuit so i can't use that.
for as far I can find I must connect it to the PCM module connection 32 ( output speed sensor, the wire that has T14 in it).
wiring diagram 8W-31-5.
am i right with this?
is there somebody who did this before?
is there an easier way to get a speed signal?
dutchHEMI is offline   Reply With Quote
Old 04-12-2005, 04:28 PM   #2
TR1?? Your thoughts?
Old 04-12-2005, 09:58 PM   #3
Dan, the Nice Guy's Avatar
I will look too. I thought the new Nav systems used the PCM-Bus module to get the speed signal. You might need a converter inbetween the connector pin 32, if the t14 cant send the signal for the Blaupunkt to understand. I will check into it.
Dan, the Nice Guy is offline   Reply With Quote
Old 04-14-2005, 01:23 PM   #4
Dan your right the new nav systems use the pcm-bus.
I see it like this, the sensor gives the pcm module a simple puls ( on of )on connection 32. The module changes that in to computer language and sends it through the pci circuit thats connected to the inst.cluster, the factory nav system etc.
So i think i can use the connection 32 that should be understandeble for the blaupunkt nav system, i don't think i wil need a converter using this connection.
It would be nice to know for sure if i'm right.
Í didn't had the time to bild the system in yet but when i do and it works i'll let you know.
( sry its not easy to explane it in technical englisch )
Old 04-14-2005, 04:44 PM   #5
Okay, I need to know the model number on the Blaupunkt nav.
Old 04-15-2005, 12:14 PM   #6
its a blaupunkt RNS 150....but i don't think its being sold in the US.
I do know all the blaupunkt models need the same puls, I bild them in semi's myself and i use the same puls for pioneer, becker, jvc, etc.
thanks for looking in to it but don't make to much work of it, i'l try it soon.
Old 04-24-2005, 02:34 PM   #7
Dan i've got the nav system working...the connection 32 didn't work, the puls goes to 0 every time the gearbox shifts...I used a signal from the ABS, its connector C1 on the abs controler under the hood...pin 2 DG/WT...you can find it in the manual on page 8w-35-2 and 8w-80-52...I'm sure you can use it for other brands aftermarket nav systems also and you don't need a converter...
I hope this wil help other members that want to build in a nav system.
