Auto Meter, how do I tie in gauge light to existing dash lights? - Hemi Truck Club
Old 08-19-2010, 05:32 PM   #1
tigman250's Avatar
Hello all, I was wondering how I tie in the light for my Auto Meter gauge light to work with my dash lights? I want it to come on and dim with the factory gauges. In the directions it says it's a Led light will it work if I just tie it in to the lighting circuit or would I need a resistor in line? Also, does anyone know of a online wiring schematic I could use to locate the correct wires?
Thanks!
Old 08-19-2010, 11:05 PM   #2
CharonBlk07's Avatar
I'd pull your light switch and tap into the dimmer line rather than trying to go into the cluster. There should only be 4 lines running in/out of the back of the switch, so get a volt meter and check for passing voltage in each line as you lower the dimmer intensity to determine which line you need.
CharonBlk07 is offline   Reply With Quote
Old 08-23-2010, 11:15 PM   #3
The Engineer's Avatar
I'd email autometer. They'll tell you within a day. They sent me a beautiful graph on my Pyrometer gauge on the diesel for wiring.
The Engineer is offline   Reply With Quote
Old 09-20-2010, 12:37 PM   #4
afteamroper's Avatar
afteamroper is offline   Reply With Quote
Old 09-20-2010, 11:54 PM   #5
madcat's Avatar
LEDs typically don't "dim"... they are either on, or off. Just tap into any "courtesy light positive wire" circuit for the gauge to follow the dash lights on/off.
