AC blower motor - Hemi Truck Club
Old 08-04-2010, 04:46 AM   #1
AC blower motor
I have a new issue. My blower motor for the A\C - heater is acting up. I have an 03 regular cab short. Before now once in a while while driving I would hit a bump and the blower would stop. I could reach under the column and wiggle the wires leading into it and the blower would come back on. Or if I adjusted the wheel up and down it would come back as well. Now all that being said it quit all together recently. Does anyone have any idea which wire would be in the column that would have anything to do with the blower motor? Or any idea what the issue may be as a whole? Thanks guys.
Miki
stlmikie is offline   Reply With Quote
Old 08-04-2010, 04:20 PM   #2
5SpeedHemi's Avatar
Miki
My blower motor problem was due to a bad ignition switch , sent you a PM on what to check
Old 08-15-2010, 03:27 AM   #3
5SpeedHemi's Avatar
Any luck finding the problem ?
Old 08-15-2010, 07:33 AM   #4
mindy's hemi "Satch"'s Avatar
Just got done replacing my BURNT ignition switch module and the connector assembly I had the same symptoms. Picture here if it makes it.....
mindy's hemi "Satch" is offline   Reply With Quote
Old 08-15-2010, 03:51 PM   #5
Yeah 5speed. That was it. Easy fix once you diagnosed it. Just in time too. It has been really hot here. Thanks a ton. If you were here now I would kiss your face.
Old 08-15-2010, 04:31 PM   #6
5SpeedHemi's Avatar
Mine had a similar look to it before I replaced it
Old 08-15-2010, 04:33 PM   #7
5SpeedHemi's Avatar
Glad I could help ..we have a stand in double for kisses his name is Superjay he should be along shortly
Old 08-15-2010, 07:44 PM   #8
tazassape's Avatar
My A/C is doing the same thing. Where is this culprit? How does one trouble shoot this? Thanks
2011 4X4 2500HD HEMI
tazassape is offline   Reply With Quote
Old 08-16-2010, 05:07 PM   #9
5SpeedHemi's Avatar
If there are over heating marks on the plug take the two plastic half's of the steering column where the key goes in off and check your ignition switch for overheating as in Satch's pic . There are three snaps down each side of the switch it comes apart in two pieces its easy to see if the contactor's are fried
Old 08-16-2010, 07:46 PM   #10
tazassape's Avatar
Thanks 5SpeedHemi I'll check it out in the morning. I knew I'd get the solution here.
