Ticking - Hemi Truck Club
Old 12-24-2017, 07:07 AM   #1
Ticking
Can anyone please tell me why I have a tick right here?
Deaton17 is offline   Reply With Quote
Old 12-24-2017, 08:26 AM   #2
I doubt that you have a tick there. Those plastic manifolds magnify noises and makes it close to impossible to nail down. However the list of culprits include, worn push rod, worn rocker, worn lifter, broken valve spring. New to my list is the rocker arm slipping side to side on the shaft. I would start by removing valve cover and inspecting everything valve train related. Have someone turn the motor over while you watch. Good luck.
Old 12-24-2017, 08:33 AM   #3
It has new lifters, valves and pushrods.
Old 12-24-2017, 09:20 AM   #4
It did jump time and it bent #3 valve and pushed. Could it have messed up the rocker arm?
Old 12-24-2017, 02:10 PM   #5
With that many parts changed I would check the rockers for the side slip I previously mention. Then measure the push rods for length or damage.
Old 12-24-2017, 03:36 PM   #6
Thanks I will look. Would this cause a slight miss?
Old 12-24-2017, 04:09 PM   #7
Most likely not unless it is something really off.
Old 01-21-2018, 01:27 PM   #8
Finally got warm enough to work on it some more. Ok when you say side slip does that mean I can move the rocker side to side when it's tighten down? Because I can on 2 of them.
Old 01-21-2018, 03:35 PM   #9
Yes, i was talking about the rocker body slipping side wise on the shaft. Its a judgement call on whether you think it is bad enough to cause the noise you have.
Old 01-21-2018, 03:35 PM   #10
The rockers will wiggle on the shafts side to side a little when not on lobe of cam. Did the push rod get bent when the valve got bent or is it all new stuff?
