Stock Front Coil Springs? - Hemi Truck Club
Old 04-08-2016, 03:44 PM   #1
Does anyone know how tall the stock front coil springs are on a 2014 R/T?
I do it cuz I can!
Daneaux is offline   Reply With Quote
Old 04-08-2016, 04:07 PM   #2
Tyler
TYSENUS's Avatar
2 or 4wd?
Mods:
Old 04-08-2016, 04:15 PM   #3
Tyler
TYSENUS's Avatar
Actually better yet, if it is the springs in the front of your truck, PM me the vin I will be able to get you a measurement. Springs are sent from Chrysler with just a tag on them, not in a package, so they also give measurements for them that you could use if you had to ship them. I can use these measurements to give you the height. This will be the unloaded height which I imagine is what you're looking for.
Mods:
Old 04-08-2016, 06:36 PM   #4
It's a 2 WD. The vin is: 3C6JR6CT1EG226092.
What I'm looking to do is find another type vehicle, Drango, Challenger, etc., who's spring are somewhere between the stock springs of my truck and the BellTech 2" lowered spring. I installed 2" drop spindles, love the stance, but front end was a tad, as in about 1/2-3/4", too low. I reinstalled the stock springs, and now i have way too much clearance. She's bull frogging on me and quite simply looks like crap.
Any help is greatly appreciated.
I do it cuz I can!
Old 04-08-2016, 06:49 PM   #5
Tyler
TYSENUS's Avatar
Ok it tells me a length of 38.10 centimeters or 15 inches.
Mods:
Old 04-08-2016, 07:36 PM   #6
Thanks! Any idea where to start looking for stock springs that run about 14"?
I do it cuz I can!
Old 04-08-2016, 08:58 PM   #7
Tyler
TYSENUS's Avatar
I would take it to a place that can make you a set. Way up here we have a company called United Spring & Brake that primarily deals in things like that for tractor trailer units but they do build custom build leaf springs, u-bolts, and coil springs. Not to mention they do this for usually a fraction of OEM prices. Perhaps you have a similar type of business near you?
I will be at work tomorrow and checking in on here. I can check some numbers to see if I can find a spring around that height but the biggest problem is that I would have no information as to the spring rate and if it will actually fit your application. It would purely be trial and error.
Mods:
Old 04-09-2016, 10:16 AM   #8
Exclamation
I would think spring rate, material quality, etc. would all be important considerations...
Old 04-09-2016, 11:24 AM   #9
If the coil spring is too long, Trim it using a cutting wheel. On my 03 I cut about a quarter of a coil at a time until I got the fender gap where I wanted.
Old 04-09-2016, 11:49 AM   #10
Exactly. I wish I could find a coil spring comparison chart so I could match up the tension, etc, with the size that I need. Any idea where I can find something like that?
I do it cuz I can!
