Rear View mirror/Radar detector - Hemi Truck Club
Old 10-30-2017, 09:56 AM   #1
Can I get 12 volts from the wiring in the rear view mirror to power my Radar Detector..
Big Tom is offline   Reply With Quote
Old 10-31-2017, 03:28 AM   #2
Lightbulb
You certainly should be able to...I'm running my escort that way on my '05. There are neat aftermarket short wiring kits available with blade adapters that easily plug into the rear mirror connections for a clean installation. Also there are 'mirror post' mounts for your detector that will clean things up and eliminate the suction cup crap that will eventually fall off...
Old 10-31-2017, 06:18 AM   #3
Thanks for your reply.
I have gotten replies on another forum telling me to not add on to an existing circuit because the computer in these new trucks will get upset.
I guess I need to fill in my Signature. Truck is a 2017 2500 6.4 Hemi
Old 10-31-2017, 07:42 AM   #4
Exclamation
Not completely certain about the Gen 4 Rams but I don't see why it would not work equally as well as it does on my Gen 3 - '05. The mirror configuration cannot be all that different...use a volt meter to check output options...on my '05 it uses the last two options (pointing towards the passenger side). Your detector uses virtually no power and shouldn't be a drain on the system. Let us know how it works out .
Old 10-31-2017, 09:03 AM   #5
Will do..
Surprise AZ,
PGR Rider and Road Guard
2017 Ram 2500 4WD 6.4 Hemi
2015 Subaru Outback
2006 Gold Wing
1999 Valkyrie Interstate
Old 11-01-2017, 04:41 AM   #6
The detector is to small to cause an issue you should be fine.
