Ram Eagle Engine Specs from Chrysler Tech Manual - Hemi Truck Club
Old 07-15-2012, 06:17 AM   #1
Mr. Freeze
VA4MEDS's Avatar
Mr. Hemi might want to sticky this
SPECIFICATIONS
Eagle Engine - 90° V-8 OHV
Metric / Standard
Displacement 5.7 Liters / 348 CID
Bore 99.5 mm / 3.92 in.
Stroke 90.9 mm / 3.58 in.
Compression Ratio 10.5:1
Max. Variation Between Cylinders 25%
Firing Order 1-8-4-3-6-5-7-2
Lubrication Pressure Feed - Full Flow Filtration
Cooling System Liquid Cooled
Cylinder Block Cast Iron
Cylinder Head Aluminum
Crankshaft Nodular Iron
Camshaft Cast Iron
Pistons Aluminum Alloy
Connecting Rods Powdered Metal
CYLINDER BLOCK
Metric / Standard
Cylinder Bore Diameter 99.50 mm / 3.92 in.
Out of Round (MAX) 0.0076 mm / 0.0003 in.
Taper (MAX) 0.0127 mm / 0.0005 in.
Lifter Bore Diameter 21.45 - 21.425 mm / 0.8444 - 0.8435 in.
PISTONS
Metric / Standard
Clearance
Measured at 38.0 mm / 1.5 in. Below Deck 0.031 - 0.058 mm / 0.012 - 0.023 in.
Ring Groove Diameter
Top Groove 90.4 - 90.6 mm / 3.56 - 3.57 in.
Second Groove 88.4 - 88.7 mm / 3.48 - 3.49 in.
Weight 413 grams 14.56 oz
Piston Length 53.3 mm / 2.10 in.
Ring Groove Width
No. 1 1.23 - 1.26 mm / 0.048 - 0.0496 in
No. 2 1.23 - 1.25 mm / 0.048 - 0.0492 in.
No. 3 2.03 - 2.05 mm / 0.079 - 0.080 in.
PISTON PINS
Metric / Standard
Clearance In Piston 0.005 - 0.014 mm / 0.0001 - 0.0005 in.
Diameter 24.004 - 24.007 mm / 0.945 - 0.9451 in.
Length 62.99 - 63.21 mm / 2.47 - 2.48 in.
PISTON RINGS
Metric / Standard
Ring Gap
Top Compression Ring 0.40 - 0.55 mm / 0.015 - 0.021 in.
Second Compression Ring 0.24 - 0.51 mm / 0.009 - 0.020 in.
Oil Control Rails 0.15 - 0.66 mm / 0.0059 - 0.0259 in.
Side Clearance
Top Compression Ring 0.04 - 0.09 mm / 0.001 - 0.0035 in.
Second Compression Ring 0.04 - .08 mm / 0.001 - 0.0031 in.
Oil Control Rails 0.06 - 0.21 mm / 0.002 - 0.008 in.
Ring Width
Top Compression Ring 1.17 - 1.19 mm / 0.0460 - 0.0468 in.
Second Compression Ring 1.17 - 1.19 mm / 0.0460 - 0.0468 in.
Oil Control Rails 0.387 - 0.413 mm / 0.015 - 0.016 in.
CONNECTING RODS
Metric / Standard
Piston Pin Bore Diameter 24.014 - 24.024 mm / 0.9454 - 0.9458 in.
Side Clearance 0.10 - 0.35 mm / 0.003 - 0.0137 in.
CRANKSHAFT
Metric / Standard
Main Bearing Journal Diameter 64.988 - 65.012 mm / 2.5585 - 2.5595 in.
Bearing Clearance 0.023 - 0.051 mm / 0.0009 - 0.002 in.
Out of Round (MAX) 0.005 mm / 0.0002 in.
Taper (MAX) 0.003 mm / 0.0001 in.
End Play 0.052 - 0.282 mm / 0.002 - 0.011 in.
End Play (MAX) 0.282 mm / 0.011 in.
Connecting Rod Journal Diameter 53.992 - 54.008 mm / 2.126 in.
Bearing Clearance 0.020 - 0.060 mm / 0.0007 - 0.0023 in.
CAMSHAFT
Metric / Standard
No. 1 58.2 mm / 2.29 in.
No. 2 57.8 mm / 2.28 in.
No. 3 57.4 mm / 2.26 in.
No. 4 57.0 mm / 2.24 in.
No. 5 43.633 mm / 1.72 in.
Bearing To Journal Clearance Standard
No. 1 0.040 - 0.080 mm / .0015 - .003 in.
No. 2 0.050 -0.090 mm / 0.0019 - .0035 in.
No. 3 0.040 - 0.080 mm / .0015 - .003 in.
No. 4 0.050 - 0.090 mm / 0.0019 - .0035 in.
No. 5 0.040 - 0.080 mm / .0015 - .003 in.
Camshaft End Play .080 - 0.290mm / 0.0031 - 0.0114 in.
VALVE TIMING
Intake
Opens (BTDC) 28.2°
Closes (ATDC) 239.8°
Duration 268°
Exhaust
Opens (BTDC) 274.2°
Closes (ATDC) 15.8°
Duration 290°
Valve Overlap 44°
CYLINDER HEAD
Metric / Standard
Valve Seat Angle 44.5° - 45.0°
Valve Seat Runout (MAX) 0.05 mm / 0.0019 in.
Valve Seat Width (finish)
Intake 1.18 - 1.62 mm / .0638 in.
Exhaust 1.48 - 1.92 mm / 0.0583 - 0.0756 in.
Guide Bore Diameter (Std.) 7.975 - 8.00 mm / 0.3134 - 0.315 in.
HYDRAULIC TAPPETS
Metric / Standard
Body Diameter 21.387 - 21.405 mm / 0.8420 - 0.8427 in.
Clearance (to bore) 0.020 - 0.063 mm / 0.0008 - 0.0025 in.
Dry Lash 3.0 mm (at the valve) / 0.1181 in. (at the valve)
VALVES
Metric / Standard
Face Angle 45.0° - 45.5°
Head Diameter
Intake 50.67 - 50.93 mm / 1.99 - 2.01 in.
Exhaust 39.27 - 39.53 mm / 1.55 - 1.56 in.
Length (overall)
Intake 123.38 - 123.76 mm / 4.857 - 4.872 in.
Exhaust 120.475 - 120.855 mm / 4.743 - 4.758 in.
Stem Diameter
Intake 7.935 - 7.953 mm / 0.312 - 0.313 in.
Exhaust 7.932 - 7.950 mm / 0.312 - 0.313 in.
Stem - to - Guide Clearance
Intake 0.022 - 0.065 mm / 0.0008 - 0.0025 in.
Exhaust 0.025 - 0.065 mm / 0.0009 - 0.0025 in.
Valve Lift ( @ zero lash)
Intake 12.0 mm / 0.472 in.
Exhaust 11.70 mm / 0.460 in.
VALVE SPRING
Metric / Standard
Spring Force (valve closed) 435.0 N +/- 22.0 N @ 45 mm / 97.8 lbs +/- 5.0 lbs. @ 1.771 in.
Spring Force (valve open) 1077.0 N +/- 48.0 N @ 32.6 mm./ 242.0 lbs. +/- 11 lbs. @ 1.283 in.
Free Length (approx). 55.6 mm / 2.189 in.
Number of Coils 7.95
Wire Diameter 4.95 × 4.1 mm / 0.194 - 0.161 in.
Installed Height (spring seat to bottom of retainer) 46.0 mm / 1.81 in.
OIL PUMP
Metric / Standard
Clearance Over Rotors (MAX) 0.095 mm / 0.0038 in.
Outer Rotor to Pump Body Clearance (MAX) .235 mm / 0.009 in.
Tip Clearance Between Rotors (MAX) 0.150 mm / 0.006 in.
OIL PRESSURE
Metric / Standard
At Curb Idle Speed (MIN)* 25 kPa / 4 psi
@ 3000 rpm 170 - 758 kPa / 25 - 110 psi
* CAUTION: If pressure is zero at curb idle, DO NOT run engine.
Old 07-15-2012, 06:45 AM   #2
Good info - thanks for sharing!
Old 07-15-2012, 08:57 AM   #3
HTC.com Titan Killer Club
Member # 17
