one ticked off mosse owner - Hemi Truck Club
Old 04-03-2013, 10:42 PM   #1
Mr big country's Avatar
Exclamation one ticked off mosse owner
Hey everyone looooonnngggg time no typin for me on here life has been taking me in all different directions. But now I am able to be back on here, now for my issue. I cant possibly be the only Ram owner that has noticed that Dodge went the EXTREMELY CHEAP route for the thickness of the metal for the body on our trucks. Also where the antenna is just above it above it, i noticed after going through the car wash that the metal had clearly split.
Also under the hood on several spots the im assuming where it makes contact with the protective plastic. It is rusting from the paint being removed from rubbing.
Now on to my Hemi issue .... it is either lifter or injector tick and I have been told by two different maitnance managers who said," SIr its not broke so your warranty will not cover it." Now fellas put it this way its so loud I can hear it while in the basement and my Ram is parked on the other side of the driveway. Yeah quite loud.
Oh I have a bumper to bumper life time warranty and I bought the "gold" package they offer on top of it.
Any recommendations on who I should call? Or on what I should do?
2010 2500 5.7 Hemi crew cab long bed, FRESHLY PAINTED NEW ENGINE COVER. More mods to come soon ......but now soon enough.
Mr big country is offline   Reply With Quote
Old 04-04-2013, 06:12 AM   #2
ROLLING THUNDER's Avatar
I know that I would make it to where they have no choice but to replace the engine if it is indeed under warranty
Oops, I didn't say that out loud, did I.
Old 04-04-2013, 07:34 AM   #3
5SpeedHemi's Avatar
Check the fine details of your warranty, inquire with the dealer block your number don't give your name when satisfied your covered for catastrophe engine failure go place a brick on your gas petal and blam new engine under warranty problem solved you didnt here that from me
Old 04-04-2013, 07:36 AM   #4
Exclamation
NOoO rolling thunder you didnt say it aloud but you did type it aloud lol hahaha. Thank you and this is going to be a fun filled week of issues getting taken care of. I hope they will just take care of
Old 04-04-2013, 07:40 AM   #5
5SpeedHemi's Avatar
Seriously Nathan I did not see your post there lol
Great minds think a like ..just not out loud
Old 04-04-2013, 10:21 AM   #6
FASTHEMIRAM05's Avatar
Prolly lifter tap...
Happened to my 2011 once. Had a tap that was loud as hell..
I put some Lucas oil stabilizer in it and it went away immediately.
Try it.
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 04-04-2013, 06:52 PM   #7
MikeHTally's Avatar
Dealer connects Star Scan ... finds it was run extended period with no load at high rpm ... dealer offers a small amount of lube.
Old 04-04-2013, 07:07 PM   #8
There's a rev limiter to prevent the brick on the throttle from really doing anything, not that I think that's a valid solution. Sounds like it needs the proper weight oil/oil change. If that doesn't help then I'd change push rods and if that doesn't help, you can be pretty confident it's a lifter. Assuming it isn't a leaking exh manifold.My 2 cents.
Old 04-05-2013, 11:40 AM   #9
Well they are saying no exhaust leak. The guy who did the inspection for the entire exhaust system also said there was no rattle or noise coming from the bell housing when everyone and their brother heard it and could feel it. That ended up being the all the fly wheel bolts had came loose and 2 of them were less then an 1/8 of an inch from hitting the block.
Old 04-05-2013, 11:42 AM   #10
Now I was just sitting here and thinking about it and the closest dealership that i already take my truck to get other stuff done is a great dealership and I honestly dont want to screw the techs out money due to the fact that its warranty work. But on the other hand I did spend the big bucks to get the warranty
