Looking for these connectore part # - Hemi Truck Club
Old 04-11-2019, 08:48 PM   #1
Hi
Im looking for these connectors for the 4x4 module that is on the passenger side lower under the rug. I need the 1 that plugs to the left side 8pin and the mating connector with pins also
I have been searching most of the day and could not locate any good info.
See pictures of the module and the connectors I need
dss56 is offline   Reply With Quote
Old 04-12-2019, 01:45 PM   #2
Tyler
TYSENUS's Avatar
I can't find anything where that plug is actually used. What are you trying to do with it?
Mods:
Old 04-12-2019, 01:49 PM   #3
The black module is the 4x4 interface I have a 2013 4x4 electronic 44-44 transfer case.
On the passenger side on the floor near fire wall is where this is located and looking at it the connector to the left is what im trying to find. and the connectors pictured I need to find the part #
I think they are made by Delphi co.
Old 04-12-2019, 02:04 PM   #4
Tyler
TYSENUS's Avatar
Well there are only two connectors used on that module. One you have the number for which is the 16 pin, the other is the far left four pin which is 68065020AA. The center 8 pin is not used and Chrysler doesn't service a connector for it. That is the one I was understanding you were looking for.
Mods:
Old 04-12-2019, 02:35 PM   #5
The connectors Im looking for are 16 pin connectors and connect to the far left connector port I think the part # you posted from picture is not the same it says 4 pin but the picture of connectors I need are 16 pin 2 rows of 8.
Old 04-12-2019, 02:40 PM   #6
here are better pictures
Old 04-12-2019, 03:04 PM   #7
Tyler
TYSENUS's Avatar
That is why I was confused. The picture you posted has the part number for that connector in it. 68065019AA.
Mods:
Old 04-12-2019, 03:06 PM   #8
I think its a generic picture and I hate when they do that
Old 04-12-2019, 04:10 PM   #9
Tyler
TYSENUS's Avatar
No the bottom picture you posted is right out of the Mopar connector kits site. I wasn't sure if you had access to it or if you found it elsewhere online. That is the site I have been searching and I checked everything from 2009 to 2018 and they are all the same with those two part numbers.
Mods:
Old 04-12-2019, 06:33 PM   #10
Here is a better picture of the module first picture I forgot I flipped it so I could read the numbers. Ill have to keep searching for the part#
This part #68065020AA is for the 4 pin connector to the right. And as I said the picture I posted is most likely a generic picture as it showe's a 16 pin connector
