engine lite popped up today... - Hemi Truck Club
Old 01-15-2016, 06:00 PM   #1
tried to find how to check codes on you tube got nowhere. Made sure gas cap is tight. in good condition. Looking where to start.
Carl's 5.7 is offline   Reply With Quote
Old 01-15-2016, 06:48 PM   #2
Welcome, I'm guessing you don't have a tuner to read codes. There's a trick using the ignition key on and off sequence. Your next best source is to take it to the local auto parts store and they will generally read the code for free. Write the code down and post it here. good luck. You can also use grease or vasoline to help seal a gas cap.
Old 01-15-2016, 07:53 PM   #3
Turn the key from off to run there times stopping at run on third time and the codes will read out in the odometer if your truck has the code function in it not all do
