E-Fan opinion - Hemi Truck Club
Old 06-14-2016, 10:01 PM   #1
E-Fan opinion
Anyone have any experience with a Doorman E-Fan? It supposedly and drop in, plug-n-play and has a lifetime warranty.
I do it cuz I can!
Daneaux is offline   Reply With Quote
Old 06-14-2016, 10:02 PM   #2
And on that thought, for those of you that did got to the E-Fan, what size belt did you go with after removing the blades and pulley from the water pump?
I do it cuz I can!
Old 06-14-2016, 11:00 PM   #3
I installed the Flex-a-lite 183 E-fan kit on my 07' 3 years ago. It replaced the factory fan, fan clutch, and fan shroud. The belt is the original constantine belt, there was no reason to replace it yet. The E-fan works great, and now the water pump will last a lot longer since it no longer has the clutch fan to spin. I also freed up some horsepower, along with a slight increase in fuel economy.
Old 06-15-2016, 09:24 AM   #4
David
ATXHEMI's Avatar
You dont remove the pulley. That would eliminate the water pump.
Old 06-15-2016, 09:37 AM   #5
Brian Fart over here!
I do it cuz I can!
Old 06-15-2016, 11:01 AM   #6
mjfikac's Avatar
I run the Mopar V6 fan on my trucks, but most guys go with the cheaper TYC 622320 fan. They both plug right in to the factory AC fan plug, and you do not have to change the belt. All you are doing is removing the clutch fan from the water pump pulley...not removing the water pump pulley itself.
Its a good cheap upgrade.
2011 Ram 1500 RC/SB 5.7L
11.99 @ 110.66 MPH N/A
11.09 @ 120.13 MPH Nitrous
2014 Ram 1500 RC/SB 5.7L 8SP
1/8 - 6.54 @ 108.88MPH
1/4 - 10.43 @ 136.25MPH
Old 06-15-2016, 02:14 PM   #7
Tyler
TYSENUS's Avatar
Who's Brian?
Mods:
Old 06-15-2016, 03:11 PM   #8
FASTHEMIRAM05's Avatar
Got a dual fan setup off a semi for mine
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
2011 Drag Truck....
Old 06-16-2016, 10:18 AM   #9
Board of Directors-Bill
arocketman's Avatar
Nice.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 06-16-2016, 02:55 PM   #10
Looks strong. What is the CFM output?
