3 way coolant valve P26A7 - Hemi Truck Club
Old 10-31-2016, 11:53 AM   #1
I need help. I replaced the 3 way valve and it didn't work. Anyone got any ideas or info? The only thing I have left is disconnecting the battery.
Ram 1500 bighorn 2014 is offline   Reply With Quote
Old 10-31-2016, 11:56 AM   #2
Code P26A7 is still on. I did have code P26AB but it went away. CEL is on. Also transmission will not heat up to operating temperature. It runs at 150 degrees. If working properly it should be around 180. I have a 2014 ram 1500 5.7 HEMI 8 speed 2wd Thanks
Old 10-31-2016, 03:02 PM   #3
Matt
MANual_puller's Avatar
That code is sensor circuit high, there's got to be a wire broken off. Dead short would be circuit low. Tug on all the wires at the plug and see if anything is loose. I've seen the plugs break and the spade of one wire push out instead of together and I've also seen bad crimps pull loose. Hopefully it's something simple like that
Old 11-03-2016, 01:49 PM   #4
Coolant valve
Your speaking of the wire connected to the 3 way coolant valve right? I have tried all of that. Do you know the parts number to that cord?
