2 Pillar Pods - Hemi Truck Club
Old 12-05-2015, 03:47 PM   #1
2 Pillar Pods
If you had to chose 2 gauges for your pillar pod, which two would you chose and why?
I do it cuz I can!
Daneaux is offline   Reply With Quote
Old 12-05-2015, 05:32 PM   #2
Wideband for AFR watching on boost/spray apps.
Trans temp
Old 12-05-2015, 06:32 PM   #3
AeroForce Interceptor and w/band. Interceptor reads multiple sensors and two can be selected at a time to monitor. W/band for AFR...
Old 12-05-2015, 08:36 PM   #4
I run an AutoMeter engine oil pressure gauge to monitor the engine's life blood, cause I don't trust the dash gauge. I also run an AutoMeter Trans. Temp gauge to monitor the temperature of my transmission fluid.
Old 12-06-2015, 06:24 PM   #5
Talking
One of the gauges needs to be a 'bank-account-monitor' that allows us to see how quickly MODS change our balance .
Old 12-06-2015, 06:29 PM   #6
If I had one of those, I would bury the truck and sell treasure maps.....
Old 12-07-2015, 09:36 AM   #7
Tyler
TYSENUS's Avatar
I run a wideband for air/fuel and oil pressure. The factory gauge is just a dummy light that jumps the needle up at 6 psi.
Mods:
Old 12-07-2015, 07:09 PM   #8
Matt
MANual_puller's Avatar
That is exactly what I want to run. I may do the triple pod and mount my trinity there too instead of continuing to use the windshield mount
Old 12-07-2015, 09:55 PM   #9
Gold-Member
kcd1369's Avatar
That's what I'm about to do once I get my gauges. I have a single now, with the trinity. But I just got a triple, that needs some paint before it goes in. To many projects, too little time.
Old 12-07-2015, 10:34 PM   #10
One day I'll take the plunge an get 3 more gauges an put them in the cubby in the dash. Wanna keep it not as visible from outside
