04-19-2017, 01:03 PM
#1
Misfire HELP
Ok so I was getting a misfire code on cyl 7 on my 05 hemi, I was getting intermittent stalling but truck seemed to run normal, I changed plugs (champion coppers) and wires (taylor shorties) and replaced cyl 7 coil pack, now it's missing really bad no power and throws cyl 1 and 7 misfire codes, I unplugged the harness and I'm getting .2 volts to 1 & 7, and about 3.6 volts to 3,5,2,4,6 & 8, I looked at the wiring and I'm not seeing any cut or burnt wires, could it be the coil drivers in the ram, I'm not sure what to do next, I really don't want to go to the stealership
