Wot switch - Hemi Truck Club
Old 04-04-2007, 04:20 PM   #1
Wot switch
where did you guys mount your switch for the 5.7?
Im allmost done all my wiring and need to mount the wide open throttle switch?
BnB4Ever is offline   Reply With Quote
Old 04-04-2007, 04:43 PM   #2
Wot switch
I hold mine. I know of people putting it under the pedel though.
Old 04-04-2007, 05:05 PM   #3
Wot switch
I have a push button wire I was thinking about useing... but i rather have a setup that is linked to throttle some how... no way I want to drill holes in floor for this switch... any way to mount it in the engine compartment to a linkage or something?
Old 04-04-2007, 05:30 PM   #4
Wot switch
I think you would need an electric switch.
Old 04-04-2007, 10:17 PM   #5
Wot switch
I used a WOT micro switch mounted above the pivot on the bracket that holds the pedal assembly, i just reversed the switch so it faces in and made a longer bracket, seems to work good, no holes through sheet metal or holes where people could see
Old 04-04-2007, 10:19 PM   #6
Wot switch
you can also purchase electonic TPS switches, dynotunes is 69 bucks
Old 04-05-2007, 04:09 PM   #7
Wot switch
http://mysite.verizon.net/vze7erz1/id1.html
RPM window switch much safer then a WOT Im going to get one set to 3000 RPM/on and 5500/off
http://cgi.ebay.ca/Nitrous-TPS-Throt...QQcmdZViewItem
or a ATPS switch
need to ask around to find out what would be better. This message has been edited. Last edited by: BnB4Ever, document.write(''+ myTimeZone('Thu, 05 Apr 2007 15:29:46 GMT-0700', '05 April 2007 06:29 PM')+''); 05 April 2007 06:29 PM
Old 04-05-2007, 09:49 PM   #8
Hemidup's Avatar
Wot switch
BnB4Ever, You'll be glad you shut it off at 5500. I've seen what no2 will do to the hub assemblies of the tranny if you spray it through the shifts.
Old 04-05-2007, 10:32 PM   #9
Wot switch
BNB thats a good find on a window switch, do you have any feedback on that unit, i am also interested in it
Old 04-06-2007, 08:38 AM   #10
Wot switch
Im in contact with the builder now about the adjustable RPM window switch... Im on a few forums trying to get some info or feedback about it.
http://www.egauges.com/vdo_acce.asp?...am_Console_Pod
heres another find for ya... for a clean way to mount your gauges is ya dont like the Pillar arm idea.
