Wireing help again - Hemi Truck Club
Old 08-01-2007, 02:15 PM   #1
Wireing help again
Ok guy i got the last problem fixed now.. what wires do i splice into for the RPM or Tach wire and the TPS WOT wire... what do i splice into.. to get this box to work
Tooloe is offline   Reply With Quote
Old 08-01-2007, 03:19 PM   #2
Wireing help again
the TPS wire will go to the rising or falling voltage wire
Tach signal can use the ground for the coils
n2oHemi is offline   Reply With Quote
Old 08-01-2007, 03:31 PM   #3
Wireing help again
where is this riseiing and falling wire at ? and what color
Old 08-01-2007, 04:51 PM   #4
CentralTexHemi's Avatar
Wireing help again
This is where I wired in my wide open throttle sensor wire, this up from the gas pedal where the wire comes out of the throttle control box
Old 08-01-2007, 04:55 PM   #5
Wireing help again
is that right off the gas pedal???... or do i follow it up into the engine compartment?
Old 08-01-2007, 06:00 PM   #6
Wireing help again
nvm found it "hits self in head".. and the other goes to the ground on the coil right? where abouts that located?
Old 08-24-2007, 10:23 AM   #7
Wireing help again
i am trying to wire a meth kit into my car and i need to wire it to a tach output or a rpm signal. where do i spice in
mgwarrior350 is offline   Reply With Quote
Old 08-24-2007, 04:06 PM   #8
Wireing help again
alright what kinda car if it's a 5.7 hemi there should be a a blue wire with a brown tracer.. it runs right across the top of the motor..... and if you can't find it on top of the motor it's in connecter #1 Prong 22
