Window switch tach wire/hook up location? - Hemi Truck Club
Old 07-07-2012, 07:18 PM   #1
CharonBlk07's Avatar
For people that have done a nitrous install: I'm doing a Zex window switch that requires tapping a tach wire for the switch to take the RPM settings. Can anyone tell me what wire, and where, I can tap into to get this signal? I was hoping for something not part of the cluster, there must be a connection point in the engine bay like the crank speed sensor or something, any ideas?
'09 1500 QC/RB 4wd. Cog driven F-1A Procharger, forged 5.7L, W/M injection, 4.5"/6.5" drop, SQ audio system
CharonBlk07 is offline   Reply With Quote
Old 07-07-2012, 07:18 PM   #2
Old 07-08-2012, 06:11 AM   #3
NM, found it, negative on the coil pack.
Old 07-12-2012, 05:08 PM   #4
Phill's Avatar
Which color wire is that? I have a tach/shift light to wire in.
HEMI's and Wings
Nothing better for a Sunday Drive
Homemade front tilt hood with mini MOPAR Pro Stock Style hood scoop, Self made air intake, Carr Hoops steps, Glasscapes window treatment, AVS chrome taillight covers and in channel visors, custom dual exhaust with Dyno Max muffler and cutouts, custom 'hockey stick' graphics, SportMaster Tonnue cover,ECCO 80w Corner strobe Kit, VR3 Back up camera system, MOPAR Rear wheel well liners, Superchips3815,purple neon underbody kit and windshield washer LED's
Phill is offline   Reply With Quote
Old 07-12-2012, 06:51 PM   #5
For mine it was the brown/white wire, but every coil pack had the same ground wire color on it so it's easy to figure out which one it should be. I've read about others using the injector ground wire as well.
Old 07-13-2012, 09:28 AM   #6
I wouldn't recommend connecting to the injector wire as the PCM can diagnose electrical faults in the injectors.
Sold: 2003 Dodge Ram 1500
Old 07-15-2012, 06:10 AM   #7
Phill's Avatar
Ok , thanks
HEMI's and Wings
Old 07-22-2012, 08:38 AM   #8
Just returned home from a trip, trying to catch up with everything. I've installed a AutoMeter Tach adapter which is a bit of a PIA as you have to re-configure the coil wiring. The Tach Adapter makes a solid square wave for a output signal. But with the hassle of install I'd recommend just going with a tap off of a coil.
