Nitrous & Ring end gap - Hemi Truck Club
Old 04-12-2010, 09:30 AM   #1
Here's a picture of what happens when ring end gap is not set correctly for Nitrous. The ring end gap went solid, and broke the piston part above. This is a fairly rare picture, as the piston came down on the ring, and locked it in the closed position.
HTC.com Titan Killer Club
Member # 17
Old 04-12-2010, 09:30 AM   #2
Member # 17
Old 04-12-2010, 02:19 PM   #3
Here's a question for you Jay. A stock 5.7 hemi piston and rings, running 10 psi boost. What should the ring gap be at least? Or, running a 125 shot of NOS? These questions just popped in my head when I looked at that piston. It makes me want to pull my engine out, take it apart, and add at least .015 more to my ring gaps.
Old 04-13-2010, 06:12 AM   #4
Nitrous Street, .005 per inch of bore.
10 lb. boost, .006 per inch of bore
Nitrous Race, (250 horse, or more), .007 per inch of bore.
The above numbers are not "cast in stone", as other factors can come into play!
Member # 17
Old 04-19-2011, 07:39 AM   #5
Mr. Freeze
VA4MEDS's Avatar
Another question Jay,
2010 Hemi Ram 9,400 miles Shifting 5950. Rev limiter 6200.
How large a shot of nitrous can I handle safely w/WOT switch over 3,000 rpms?
On Diablo Perf tune they say 3 degrees advance timing for that. So I'll deduct that first & 2 degrees @ every 50 hp shot.
Is my figuring correct? If not please enlighten me "Oh Knowledgeable One".
Old 04-19-2011, 08:07 AM   #6
With the key word here, being safely, 100 shot, maybe 125. I'm sure we'll hear from members that have so far successfully used more. In yer case, the motor is just broken in. Still tight factory clearances. As a motor wears, cylinder bore will increase, thus making larger ring end gap. You need to clarify yer timing statement better, for me to answer.
Member # 17
Old 04-19-2011, 11:52 AM   #7
Mr. Freeze
VA4MEDS's Avatar
To clarify my timing question:
DS claims to add 2-3 degrees in their canned perf tune.
I thought I should pull DS's 3 degrees before I pull an additional 3 degrees (6 total) for a 75 shot.
What do you think? Soon as I can find some decently priced headers I'll get a custom tune.
Thanks in advance.
Old 04-20-2011, 02:12 AM   #8
Correct!
Member # 17
Old 04-20-2011, 04:04 AM   #9
Mr. Freeze
VA4MEDS's Avatar
Originally posted by Superjay:
Correct!
Thanks Jay!! I thought I was correct in my thinkin' but I needed the Motor God to confirm.
Old 04-22-2011, 03:31 AM   #10
Board of Directors-Bill
arocketman's Avatar
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
