New Nitrous Guages - Hemi Truck Club
Old 11-15-2007, 02:37 PM   #1
CentralTexHemi's Avatar
New Nitrous Guages
Instuction for V Gauge ---> http://www.trickperformanceproducts....nual_ver_d.pdf
V is the only gauge in the world that can answer that age old question that has been asked for decades, “How much nitrous do I have left in the tank?” Its computer processor core can calculate how much nitrous you are using and how much is left when done. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any nitrous system from single stage simple systems up to dual stage progressive systems; even the purge usage is calculated. You simply program the unit to your nitrous system. V is not just a gauge it’s a controller as well. V can; control the heater, shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. A warning flash will let you know you have a problem and where that problem is. V will tell you, your nitrous pressure, fuel pressure or O2 reading, if the heater is on or off, nitrous level in % form, and nitrous level in color bar graph form. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 3 main viewing screens to choose from with just a push of the control button. Fits any 2 1/16 gauge pod. You also get to choose your bottles color with in the display.
Vcan take the place of :
• 1 Nitrous Pressure Gauge
• 1 Nitrous Pressure Shut Down Switch
• 1 Nitrous Heater Toggle Switch
• 1 Fuel Pressure Gauge
• 1 Fuel Pressure Safety Switch or FPSS
• 1 Air/Fuel Gauge (Instead of Fuel Pressure Gauge/ FPSS)
• 1 Air/Fuel Shut Down Switch (turns nitrous system off if running lean or rich requires a wideband with programmable output)
• 1 Heater Control Pressure Switch
• 1 Digital Bottle Weighing Scale
*Pressure sensors are required for any pressure reading, and for heater control feature to work.
Old 11-15-2007, 02:37 PM   #2
New Nitrous Guages
Instruction for P Gauge ---> http://www.trickperformanceproducts....nual_ver_d.pdf
P is the only gauge in the world that is a progressive controller with mutli-point ramping capabilities. Its computer processor controls the nitrous system completely including the heater. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any single stage nitrous system. You simply program the unit to your nitrous system. P is not just a gauge it’s a controller as well. P can control the heater and shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. It’s a progressive controller, window switch, TPAS switch, nitrous pressure gauge, shift light. A warning flash will let you know you have a problem and where that problem is. P will display, your(nitrous, boost, fuel, or oil pressure), O2 reading, is the heater on or off, nitrous progressive level, rpm, inside or outside the window switch setting, WOT activation. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 8 main viewing screens to choose from, with just a push of the control button. Fits any 2 1/16 gauge pod.
• Progressive controller (time or rpm based)
• RPM window switch
• Wide-Open-Throttle detection when used with factory TPS or WOT switch.
• Supports Fly-by-Wire TPS rising or falling
• 5 Point variable Progressive ramping (time or rpm based)
• Shift Light
• Rich l Lean Cutoff (when used with a wideband)
• Air/Fuel inputs Digital or Analog
• Multiple wideband capabilities
• Heater controller
• First gear lockout / delay
• 8 different Main Viewing screens.
• Programmable Power UP screen and Arm screen
• Multiple pressure choices
• Pressure display (boost, nitrous, oil or fuel)
Old 11-15-2007, 02:38 PM   #3
New Nitrous Guages
This unit is included with every P gauge. Additional unit(s) are required, if more then 1 nitrous and 1 fuel solenoids are being use.
• Small compact size fits anywhere
• 1” x 1.5” x .75”
• Water tight construction
• 40 amp capable
• Mounting tab
• Long wire leads
• Easy parallel wiring
Old 11-15-2007, 04:56 PM   #4
New Nitrous Guages
Great info
Old 11-15-2007, 05:11 PM   #5
New Nitrous Guages
Old 11-16-2007, 08:58 AM   #6
New Nitrous Guages
I can't get the links to work.
Old 11-16-2007, 09:02 AM   #7
New Nitrous Guages
www.trickperformanceproducts.com
Old 12-03-2007, 09:29 PM   #8
06hemibighorn's Avatar
New Nitrous Guages
dang those look good, couldnt find the prices for em though but i want em
06hemibighorn is offline   Reply With Quote
Old 12-27-2007, 04:54 PM   #9
Formerly 'Vince'
4dhp's Avatar
New Nitrous Guages
Very cool, I got curious and googled it a little further (more so I could find somewhere that it was dummied down a bit for me,lol).
The prices I found were MSRP:
The V Gauge $375
The P Gauge $399
The info:
THE V GAUGE.
Out of the box this gauge will offer the following fuctions.
1.NITROUS VOLUME USAGE.
2.AIR/FUEL READING. (Plugs into your wide band)
3.NITROUS SYSTEM SHUT OFF. (Shuts nitrous system of in relation to air/fuel readings)
4.Bottle Pressure gauge(Requires you buying sensor # SHP-1500- $60.75)
5.Nitrous Shut off ( You have to be using option #4 with the sensor for this to work. If bottle pressure is to high system relay will not triger)
OK,
Now that we see what it does out of the box lets talk about add on features. You are allowed to monitor one pressure using all the features that the gauge offers out of the box. This pressure has to be bottle pressure. If you do not have a wideband and do not need the gauge to be used as a wideband gauge you can use the gauge to monitor two pressures instead of one. So now you can add a second pressure to monitor. All the add on features require you buying the needed pressure switch.
Here are your pressure other options.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.A SECOND NITROUS PRESSURE
5.WATER/COOLANT TEMP
6.OTHER (any other pressure option you may need)
NOW THE P GAUGE.
Out of the box the P GAUGE offers alot of options.
1.PROGRESSIVE CONTROLLER ( Multipoint ramping with RPM and Time base options)
2. SHIFT LIGHT
3.WINDOW SWITCH
4.TPS ACTIVATION SWITCH
5.FIRST GEAR LOCK OUT/DELAY OPTION (Aids in traction limitied applications)
6.AIR/FUEL READING (Plugs into your wideband)
Ok now that we have went over what the gauge does out of the box lets go over add on features. The P gauge is designed so that if you have a digital out put wideband such as the new FJO series you can use the built in digital input that the gauge has. This now free's up a area giving you the option of adding a pressure to monitor. (You will need to buy the needed pressure switch)
Pressures you can monitor are.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.NITROUS PRESSURE
4dhp is offline   Reply With Quote
Old 01-03-2008, 01:36 AM   #10
Bill_L's Avatar
New Nitrous Guages
These look very cool. I think you might need a masters degree to program the thing.
Bill
