help...... - Hemi Truck Club
Old 08-01-2007, 04:50 AM   #1
help......
ok so i'm installing all the system stuff that i got in my nitrous kit.. well get it all wired up follow the direction to a T or so i think.....here what i'm dealing with a basic kit from nitro daves.. with a trick window switch......i get it all wired up adn when i flip the switch i guess to arm the system it clicks the sloinoids " idk maybe i missed something but i'v checked it and checked it again... the it started smokeing the NO2 silonoid... any ideas on whats happening? they are both grounded an ran to the same spot on the relay that the installation instructions say to run it to??? i'm confused????
Tooloe is offline   Reply With Quote
Old 08-01-2007, 04:59 AM   #2
D500's Avatar
help......
quote:the it started smokeing the NO2 silonoid... any ideas on whats happening? they are both grounded an ran to the same spot on the relay
Can you do a diagram of how you have it wired?
That will help me figure out what's gone wrong.
Are you using the TPS for the activation of the nitrous?
Also let me know what brand of relay and part number you are using. Some relays are wired differently than others.
Old 08-01-2007, 05:22 AM   #3
help......
idk about the diagram.. i'm useing nitrous daves installation instructions.
Part numbers
relay and harness 00-5202
n20 solenoid 00-5004
heres how i gotg it wired lets see if i can give u a mental picture
ok n2o solenoid is grounded on pass side of truck
fuel solenoid is grounded to driver side of truck..n20 solenoid power wire is ran to fuel power wire where they go to the same spot on the relay "87"
Old 08-01-2007, 08:38 AM   #4
CentralTexHemi's Avatar
help......
Wade, drive it over to his shop in Hewitt, call me and I can give you directions but you will need to call him or Chris to let them know you are coming
Old 08-01-2007, 01:14 PM   #5
help......
yup thats prob what i'm end up doing.... but i'ma double check 1 more time in case i messed up some where
Old 08-01-2007, 02:01 PM   #6
help......
well i found it.. after talking.. with them over the phone./. got it fixed in less trhan 5min.. had 1 wire grounded that shouldn't have been
Old 08-01-2007, 03:24 PM   #7
help......
Typical blonde mistake Do you know where to get your bottle filled, if not its called Precision Machine and its on Bagby Dr. Just take the Hewitt exit on the way to your girlfriends house which is sunvalley road and the first light you come to is Bagby, turn right and its just up on the right, go in one of the side doors and take your bottle in with you
