Eagle 5.7 Spark Plug Options for Nitrous - Hemi Truck Club
Old 02-22-2012, 04:53 PM   #1
FASTHEMIRAM05's Avatar
I didnt come up with this but glad someone did and a Big Thanks goes to them.
Hopefully this is all accurate and hopefully it is helpful for those of you looking for a colder spark plug for your 5.7 Eagle heads. These are some of the options that you have… I am sure there are more.
Note: All of these plugs have a gasket/washered seat vs. a tapered seat like that found in the pre-Eagle 5.7 and in the 6.1
NGK SPLZFR5C11
SP = platinum;
L = thread reach 26.5mm;
Z = extended projected tip;
F = 14mm thread, 19mm reach, 5/8" hex, gasket/washered seat;
R = resistor;
5 = HR 5;
C = firing end construction;
11 = 1.1mm gap
- Application: 5.7 Eagle OEM – This is what Chrysler puts in
- Using these specs, I'm looking for something colder
NGK ILZFR6D11 (Stock #1208)
I = Iridium;
R = resistor;
6 = HR 6;
D = firing end construction;
11 = 1.1mm gap
- Application: 2006/2007 BMW L6 3.0L
- One step colder than OEM plug
- Would be perfect if it weren't twice the price of everything else and nowhere to be found!
NGK LFR6AIX-11 (Stock #6619)
Iridium IX Plug,
14mm Thread Size,
26.5mm (1.04") Reach,
5/8" (16mm) Hex Size,
Gasket Seat,
Resistor,
Projected Tip,
Fine Wire (0.6mm) Iridium Center Electrode,
Tapered Cut Ground Electrode,
.043" (1.1mm) Gap,
Heat Range 6
- This would work fine
NGK LFR7AIX (Stock #2309)
Iridium
Iridium IX Plug,
14mm Thread Size,
Gasket Seat,
Resistor,
Projected Tip,
.031" (0.8mm) Gap,
Heat Range 7
- This would work fine and can be re-gapped as high as .039" as NGK does not recommend re-gapping > +/- .008”
- Two steps colder than OEM
BRISK ER14YS
E = Gasket Seat, 14mm Thread Size, 26.5mm (1.04") Reach, 5/8" (16mm) Hex Size
R = Resistor
14 = Heat Range (Different scale than that used by NGK – Brisk considers this about 1.5 steps colder than the OEM NGK plug
Y = Projected Tip
S = Silver Center Electrode,
- This is the plug that I chose for my 419 CID, 11: 1 compression, 480RWHP, NA stroker
- 1.5 steps colder than OEM
- If it didn't have a 'Projected Tip', it would be considered 2 steps colder
- Brisk recommends that I gap it between .032" and .035"
** Thanks to the smart guys that helped me out!! Fargo59, Andy at PWR and Adam at Eastway **
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 02-22-2012, 06:27 PM   #2
I think these autolites will work as well
http://www.autolitesparkplugs....o.asp?AAIA=&pid=8187
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 02-23-2012, 05:03 AM   #3
Cool spark plug finder for NGK's
http://ngk.com/search_char.asp
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 05-24-2015, 03:42 PM   #4
YEA ITS A HEMI
What plugs should I go with them for 100 shot
'12 Reg Cab Short Bed 5.7 Hemi Sport Deep Cherry Red Metallic
Mopar sport performance hood , 2/4 drop bell tech street performance shocks, bell tech track bar relocater, OEM RT 22 inch wheels, S&B CAI, catch can, JBA long tube headers with cats deleted, diablo trinity tuner,Magnaflow 12288 with removed resonators, RER Nav stereo with allgig and backup camera,
Black weather tech floor mats, strobe lights, 180 tstat, 87mm throttle body, Clutch fan delete
maka is offline   Reply With Quote
Old 05-24-2015, 05:42 PM   #5
Denso 3381's worked well for both myself and Al
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 05-24-2015, 05:45 PM   #6
YEA ITS A HEMI
That's what I'll be ordering. I've been searching for hours trying to find something out but I'm getting different answers and headaches looking.
Old 05-24-2015, 05:46 PM   #7
Gap them to .032
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
Old 05-26-2015, 02:03 AM   #8
Board of Directors-Bill
arocketman's Avatar
‘05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 06-06-2015, 12:33 PM   #9
YEA ITS A HEMI
Now I feel like a dumb *** on this trinity. How do I retard timing 4 degrees? Bout to run a 100 shot. Last night my 75 shot felt like it didn't make a difference much. And I'm running rich on a stock tune. Hoping these plugs fix that. I'm installing them now.
Old 06-06-2015, 04:06 PM   #10
Dont need to pull 4 degrees for a 100 shot...
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
