best nitros kit to use for a 04 qc. - Hemi Truck Club
Old 04-22-2007, 02:41 PM   #1
ok so im getting ready to put the dodge on the juice. and im trying to figure out who has the best kit out for the 04 dodge ram.
i want to get a wet kit
also i heard about a window switch and a rpm switch where do i find these. also what spark plugs should i run and at what gap.
thanks guy i cant wait to get this thing ready to go to the track. im wanting to be in the 13's but im hoping to safely run a 100-125 shot amd get into the low 14's.
HemiRoid04 is offline   Reply With Quote
Old 04-22-2007, 02:48 PM   #2
CentralTexHemi's Avatar
Get the Zex kit, easy install and safest for first time users, use the NGK 4306 spark plugs you will need 16 of them gapped at .035 and the progressive controller is made by FJO.
Old 04-22-2007, 02:57 PM   #3
You'll get mixed emotions on this one between ZEX and NEX, I suggest doing a search of prior topics and at least familiarize yourself with the safeguards...both systems are good....!!!!!
Rickster
Rickster is offline   Reply With Quote
Old 04-22-2007, 05:12 PM   #4
I like my dynotune system, they have a nice window switch with TPS activation, it also allows you to lock gears out and is ready for a second stage
Old 04-22-2007, 05:48 PM   #5
bigkumadog's Avatar
I ordered the ZEX #82176 Hemi Truck Nitrous System. I just plumbed it today and will wire it next weekend as I'm installing dual tanks, auto openers, rapid fire purge, timing window control unit and a lot of switches so it's going to take some time. What's nice about the kit is that it has a direct plug in fuel tap no modifying of fuel system.
Old 04-22-2007, 05:56 PM   #6
They all have a direct tap to the fuel rail it is a -4an connection
Old 04-22-2007, 07:35 PM   #7
bigkumadog's Avatar
My fuel tap just plugs between the fuel line and rail with factory connections on both ends just pop off the fuel line and pop in the adapter done.
Old 04-22-2007, 07:38 PM   #8
bigkumadog's Avatar
here is another pic.
Old 04-22-2007, 07:49 PM   #9
Looks good, mine ties into the test port with the schrader valve core removed, can you rebuild the barney box or do you have to buy another? Looks really good under the hood nice job
IMG_0097.JPG This message has been edited. Last edited by: sdogre, document.write(''+ myTimeZone('Sun, 22 Apr 2007 19:36:26 GMT-0700', '22 April 2007 10:36 PM')+''); 22 April 2007 10:36 PM
Old 04-23-2007, 04:35 AM   #10
D500's Avatar
