Wideband O2 recomendation - Hemi Truck Club
Old 06-06-2008, 02:02 PM   #1
Has anyone here added a wide-band O2 sensor to their trucks? I'm interested hearing from anyone that has done this and may be able to recomend the best kit to use. I'm not interested in only reading the sensor, but also in setting it. IOW, I want a setup that replaces the signal from the stock sensor with a custom one that allows setting the ratio. This would then trick the ECM by sending the expect how/low voltage around the new ratio as specified. Anyone suggestions? In case you're curios, this will used to allow for custom fuels.
Mcstar is offline   Reply With Quote
Old 06-06-2008, 03:59 PM   #2
I am using an Innovate LC-1 wideband with XD-16 gauge. I have replace the factory O2 sensor with one of the programmable outputs, as you asked about. Works extremely well, and is easy to set up. (can run whatever ratio you want in closed-loop operation)
Old 06-06-2008, 10:01 PM   #3
quote:Innovate LC-1 wideband with XD-16 gauge
Nice find, thanks for the tip!
