What about an 08 PCM swap? - Hemi Truck Club
Old 11-24-2017, 12:08 PM   #1
ric3xrt's Avatar
Thoughts ,Pro's? con's ? I've read a few times that the transmission tuning is better than the 05 ?
Is the 08 that much different ? just trying to think outside the limited option box.
Old 11-24-2017, 04:13 PM   #2
I believe 08 was the first year using canbus. It is the last year using a 32 tooth reluctor wheel. But havent looked into it.
Old 11-26-2017, 06:55 AM   #3
What is that?
Old 11-26-2017, 06:57 AM   #4
Would say you need to talk to a cmr tuner to see if they have the same tuning capabilities as an 05 pcm. Nobody has said anything bad about the 08 pcm.
Old 11-26-2017, 06:59 AM   #5
ric3xrt's Avatar
I was just thinking about it more in terms of having a better handle on 545 trans tuning.
Stu I'm not sure how to explain the Canbus now Cannabis
Old 11-26-2017, 07:20 AM   #6
Dont try to light this one up.
Control Area Bus, it's sharing information on a twisted wire pair. I "think" 08 they expanded the use of can-bus making the 08 pcm transitional with the changes that came in 09+.
Old 11-26-2017, 07:23 AM   #7
Originally Posted by Ghost03hemi View Post
What is that?
Old 11-26-2017, 07:29 AM   #8
The 2007+ when it comes to tuning is 1 file where as pre 2007 it's two files. Does allow more control to a point and also is same amount of work so tuning most times is still separate charges. I'm not sure a 2008 computer will work in say a 2003-5 swap type setup.
Old 11-26-2017, 07:29 AM   #9
I would think that an 08 should have better tuning all the way around. Trans & engine. But, there hasn't been much talk about the 08 pcm? Maybe Keith or Jay Greene can shed some light on the subject?
Old 11-26-2017, 11:31 AM   #10
TooCool's Avatar
Pretty sure canbus started on the 06's. Problem with going to that set-up would probably be getting it communicate with the earlier cluster and keeping all other function's working?
