Very peculiar - Hemi Truck Club
Old 07-03-2016, 12:45 PM   #1
nsorenson's Avatar
Very peculiar
So I'm just getting into modding and I've put on a throttle bodie and CAI so far on my 04 hemi sport 1500. My truck sounds amazing even with the stock exhaust. Now I know its not necessary to burn some rubber but who doesn't like to every now and then. But now I can't even get my tires to turn over a little bit, which I could before when it was all stock. Could someone tell me why this is please.
Old 07-03-2016, 01:13 PM   #2
Odd you should not have lost anything that's for sure.
Old 07-03-2016, 01:27 PM   #3
What else has been changed other than the CAI and TB?
Old 07-03-2016, 01:44 PM   #4
nsorenson's Avatar
Nothing. However I was informed that if the air charge sensor was damaged during install that it could effect the computer and make it default.
Old 07-03-2016, 01:55 PM   #5
Where did you relocate the IAT sensor?
Old 07-03-2016, 02:18 PM   #6
nsorenson's Avatar
It's a K&N 57 so I didn't tree located anywhere other than the factory hole in the piping. However I did lose The Grommet and it will have to be silicone in
Old 07-03-2016, 02:32 PM   #7
That should not make a difference. If the electrical plug wasn't connected right it would throw a code. I would try resetting the pcm and see if that corrects it. If not then I'd say put the oem TB back on and see if that helps.
Old 07-03-2016, 03:59 PM   #8
nsorenson's Avatar
Crud I like my 87mm tb. Haha but if it doesn't help my preformace it has to go. I'll try resetting I tomorrow
Old 07-03-2016, 04:50 PM   #9
I find it hard to believe that the new TB is the problem, but replacing it with the original is a easy check. Someone might suggest that it needs supporting mods to perform probably. But it is actually an conservative TB size wise and throwing more mods at it will only complicate your baseline. (Spinning tires)
Old 07-03-2016, 05:11 PM   #10
nsorenson's Avatar
I guess breaking the plastic housing around the air charge sensor has something to do with it which I did but the metal wires we're still connected. Regardless it will have to wait till after the 4th to get replaced
