Truck Running Horrible - Hemi Truck Club
Old 08-18-2010, 06:05 PM   #1
Drove the 20 miles to work this morning and when I took off at the last stop before my office, the truck would barely go. Its missing very badly, won't idle, severe loss of power, and it has a loud tap coming from the valvetrain. The tap is similar to the "Hemi Tick" but a lot more noticeable. Any ideas? I've had the 6.1 cam for probably 40K miles, long tubes, K&N, superchips. Could I have bent a pushrod or valve or messed up a lifter. Seems odd that it would have happened so suddenly. I also got a P2299 code - Brake Pedal Position/Accel Pedal Position Incompatible. This could have been just from two-footing it to keep it running. The red lightning bolt flickered a few times too. Appreciate any help you can give.
416_Demon is offline   Reply With Quote
Old 08-19-2010, 06:00 AM   #2
Sounds like a broken valve spring.
Old 08-19-2010, 07:24 AM   #3
Did you replace the valves springs when you installed the 6.1 cam?
04HEMIQUAD is offline   Reply With Quote
Old 08-19-2010, 01:48 PM   #4
We have a winner! Got the plugs out and valve covers off last night. #5 exhaust spring is trashed. Plugs looked ok so hopefully didn't drop a valve. Going to do a pressure/leak down test tonight. I did not change the springs when I installed the 6.1 can, so I am not surprised one finally broke. But getting 40K+ miles isn't too bad. I hear the 6.1 exhaust springs are a good budget upgrade for the 6.1 cam or other mild cams? What other cam could I run that would give me a little more power that will work with the 6.1 springs? I appreciate the help.
Old 08-19-2010, 07:15 PM   #5
FAhemiST's Avatar
when folks do cam swaps, 99% of them go with the 6.1 exhaust springs, no matter what cam they are putting in
Old 08-24-2010, 10:05 AM   #6
chefred112's Avatar
stick with the 6.1 springs..you can't go wrong..
